| RRSPORT.CO.UK | ||
|  | Home > Technical > EPB Strange Problem |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | Quick update on this, I've fitted a new battery this morning just to rule it out (as it was still on the original one) and it hasn't cured it   | ||
|  Mon Jan 06 2014 10:47am |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104      | IIRC blown brake lamps (or possibly any other lamp) throw up faults like this.... | ||
|  Mon Jan 06 2014 11:22am |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | So when you clear the fault code with the diagnostic tool it just reappears on the next start? 2008 MY Java Black TDV8 HSE
|  Mon Jan 06 2014 11:26am |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | @maw Brake lights all work correctly.
|  Mon Jan 06 2014 11:54am |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796    | Are they genuine LR bulbs in the brake and indicator lights, I know that people have posted that the electrics can be VERY fussy when it comes to what type of bulbs are replaced. ON THE WAY: BMW F21 M140i
|  Mon Jan 06 2014 12:03pm |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | I don't know whether the bulbs are genuine or not, none have been changed recently though. Just been and checked again that they all work, and they do. | ||
|  Mon Jan 06 2014 12:18pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | There could be an actual fault with the system (wiring) or sensor...warning lights do sometimes indicate the real problem  | ||
|  Mon Jan 06 2014 12:56pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Think I agree. Sounds like a wiring fault. Perhaps try a search for anything similar to see if there is a common place to find the exact location? 2008 MY Java Black TDV8 HSE
|  Mon Jan 06 2014 1:36pm |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | Right I Googled the C1A48 code and found a Landrover Service Bulletin, which basically said the fault was either the Parking Brake Switch, the Instrument Cluster or the wiring inbetween.
|  Mon Jan 06 2014 4:14pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Having no idea how its wired...surely if you unplug the switch then it will be a permanent fault anyway.
|  Mon Jan 06 2014 4:28pm |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | I agree that if the switch is unplugged it may then log a fault, but one of the issues I have is the 'handbrake on' warning light on the dash, even when I lock the car. I'm thinking if the switch was causing that, unplugging it would make the light go off.
|  Mon Jan 06 2014 5:08pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Did you find the full text of the TSB?  Asking because they usually have full instructions. Googling the TSB number sometimes finds the full text. You'll get there in the end so keep going! 2008 MY Java Black TDV8 HSE
|  Mon Jan 06 2014 5:35pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | The system will check the switch - if the switch is not there or faulty it will indicate a fault and you get the light, so either way unplugging will not ID the fault. Unplug and test the switch separately would
|  Mon Jan 06 2014 7:15pm |
| TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139      | Update - I've got this fixed! Traced the wiring back to the n/s/r wheelarch where the wiring loom goes over the chassis and found a wire had rubbed through and must have been earthing out. Cut the wire out and soldered in a new piece, erased the fault and it's all sorted. Chuffed to bits!
|  Tue Jan 14 2014 3:26pm |
| Posting Rules
 not always though
 not always though
