Home > Maintenance & Modifications > Not sitting level |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sounds like a compressor problem, but no doubt someone more knowledgeable will be along shortly. ON THE WAY: BMW F21 M140i
Mon Dec 16 2013 4:57pm |
mixerman Member Since: 30 Aug 2013 Location: yorkshire Posts: 21 |
It raises and lowers fine but in access height ,standard, and off road height its 25mm lower on n/s in all 3 heights. |
Mon Dec 16 2013 5:01pm |
Could be a leak then, do a quick search on here for compressor problems, it may throw up the answer, could also be a height sensor I guess. ON THE WAY: BMW F21 M140i
Mon Dec 16 2013 5:06pm |
It sits like that even with the engine and compressor running |
Mon Dec 16 2013 5:19pm |
Are there any height sensors that can be manually adjusted ??????? |
Mon Dec 16 2013 7:30pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
The system can be calibrated with a suitable diagnostic tool - the sensors themselves aren't adjustable as far as I'm aware.
Mon Dec 16 2013 8:20pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need to check out your height sensors on that side one might be sized, make sure the rubber angle rods are free to move on the upper suspension arm, it might also be one of them failing, What are the upper arm bushes like are they worn...
Mon Dec 16 2013 9:40pm |
Upper arm bushes are fine.Is there one sensor per wheel because mine is 25mm lower on both front and rear on the n/s not just the front . Do you think this is pointing more to wanting a level calibration. |
Mon Dec 16 2013 10:05pm |
