Home > Maintenance & Modifications > Not sitting level
mixerman
Not sitting level
Just parked up my 2006 RRS in garage and noticed a slight lean , on measuring the distance from the centre of the wheel to the wing lip ive found that its 25mm lower on the n/s than the o/s both front and rear. Is there any way of adjusting this so the vehicle sits level????? There are no warning messages on display. Thanks.
Post #406353 Mon Dec 16 2013 4:49pm
Sounds like a compressor problem, but no doubt someone more knowledgeable will be along shortly. Smile ON THE WAY: BMW F21 M140i
Post #406355 Mon Dec 16 2013 4:57pm
mixerman
It raises and lowers fine but in access height ,standard, and off road height its 25mm lower on n/s in all 3 heights.
Post #406356 Mon Dec 16 2013 5:01pm
Could be a leak then, do a quick search on here for compressor problems, it may throw up the answer, could also be a height sensor I guess. ON THE WAY: BMW F21 M140i
Post #406357 Mon Dec 16 2013 5:06pm
mixerman
It sits like that even with the engine and compressor running
Post #406360 Mon Dec 16 2013 5:19pm
mixerman
Are there any height sensors that can be manually adjusted ???????
Post #406372 Mon Dec 16 2013 7:30pm
The system can be calibrated with a suitable diagnostic tool - the sensors themselves aren't adjustable as far as I'm aware.
It could be problem in the main valve block next to the compressor. Hope not - they're not cheap. 2012 SDV6 - it's missing a couple of cylinders
Post #406374 Mon Dec 16 2013 8:20pm
flack
You need to check out your height sensors on that side one might be sized, make sure the rubber angle rods are free to move on the upper suspension arm, it might also be one of them failing, What are the upper arm bushes like are they worn...
Flack Thumbs Up
Post #406383 Mon Dec 16 2013 9:40pm
mixerman
Upper arm bushes are fine.Is there one sensor per wheel because mine is 25mm lower on both front and rear on the n/s not just the front . Do you think this is pointing more to wanting a level calibration.
Post #406387 Mon Dec 16 2013 10:05pm
