![]() | Home > Technical > brakes |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Sounds like worn ARB bushes. 2014 L405 SDV8 RR Autobiography |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
didnt do it though till i changed the discs and pads the other day |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Sounds like worn front lower arms bushes |
well not that i noticed! it was my lass who said it was banging, and i did a trip 60 miles and it never did it with me untill i was trying to re created what she said then thats when it did it, tbh when she was driving me stood near car i thaught it sounded like middle of car but thaught it cant be but if it has arb bush worn that would tally, need to look |
Knock when you brake sharply from low speed is usually the front lower wishbone bushes. Perhaps improving the brakes has highlighted the issue?
yeh if you creep along under 5 mph the jab the brakes it knocks.
anyone know anywhere i can buy the front lower bushes from as just bushes to press in? |
Advanced Factors |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
As said by others, probably lower arm bushes.
sparky did you have my symtoms, im thinking because i had warped discs before i was gentle with it, since i replaced discs and pads brakes are a1 and now i seem to get this noise, can anyone confirm that disco 3 has the same arms as the rrs on 2005 2,7, just ecp etc seem to list the disco stuff at around 30% cheaper than rrs items, i was going to get bushes as ive access to a press but tbh by the time ive bought a ball joint and the 2 bushes its nearl as cheap as an arm, also struggling to find the arm bush that faces to the front bumper, |
Yeah started with a knock when you brake sharp at low speed but quickly got worse and could here same knock when going over bumps, new arms sorted it though and its silent now. |
RRS bushes are different. Slightly stronger/firmer than the D3 bushes.
il just get rrs ones then, just thought it might be a scam trying to get more money from rrs owners |
