Home > Technical > brakes
shadrack
brakes
could anyone help me ive got a bit of a knock, all was fine then i did the discs and pads, now if you brake its fine but if your creeping forward in traffic and do a sharp tap on the brakes it makes a knock, got my lass to drive when i got back and cant tell which side so maybe both, its not suspension or anything, also doesnt do it in reverse, only thing i can think is either a) a calipers slightly loose or something b0 are the pads sided i.e shamfered on one edge to stop them catching the disc so sharp, wont be using till ive found it but dont know when ill get itme to look, thanks
Post #404504 Sun Dec 01 2013 10:10pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Sounds like worn ARB bushes. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #404507 Sun Dec 01 2013 10:14pm
shadrack
didnt do it though till i changed the discs and pads the other day
Post #404511 Sun Dec 01 2013 10:16pm
Disco_Mikey
Sounds like worn front lower arms bushes Thumbs Up
Common culprit of knocking noises when braking. Changed loads of arms/bushes for this exact problem Thumbs Up
Post #404513 Sun Dec 01 2013 10:19pm
shadrack
well not that i noticed! it was my lass who said it was banging, and i did a trip 60 miles and it never did it with me untill i was trying to re created what she said then thats when it did it, tbh when she was driving me stood near car i thaught it sounded like middle of car but thaught it cant be but if it has arb bush worn that would tally, need to look
Post #404514 Sun Dec 01 2013 10:20pm
Paddi
Knock when you brake sharply from low speed is usually the front lower wishbone bushes. Perhaps improving the brakes has highlighted the issue?
Assuming you didn't forget to torque up any of the bolts. We've all done it Rolling Eyes 2008 MY Java Black TDV8 HSE
Post #404518 Sun Dec 01 2013 10:23pm
shadrack
yeh if you creep along under 5 mph the jab the brakes it knocks.
going to check if tightened everything up, has happened in the past as you say weve all done it!
Post #404521 Sun Dec 01 2013 10:25pm
shadrack
anyone know anywhere i can buy the front lower bushes from as just bushes to press in?
Post #404894 Thu Dec 05 2013 1:37am
Disco_Mikey
Advanced Factors Thumbs Up
That said, the arms may need cut off, due to the bolts being seized
Post #404897 Thu Dec 05 2013 8:04am
sparky8181
As said by others, probably lower arm bushes.
Ive just had the same thing repaired a couple of weeks ago, didn't bother with bushes though, just had arms replaced as what you will save in parts just replacing the bushes you will spend in the extra labour of fiddling around with them.
Got mine from http://www.johncraddockltd.co.uk
Front Lower RH Suspension Arm 4.2 Super Charged 4.4 V8 2.7V6 2005 - 2009.
#LR029304 £89.95 1 £89.95
Front Lower LH Suspension Arm 4.2 Super Charged 4.4 V8 2.7V6 2005 - 2009.
#LR029306 £89.95 1 £89.95
Total (Exc Vat): £179.90
Total (Inc Vat): £215.88
Post #404916 Thu Dec 05 2013 10:51am
shadrack
sparky did you have my symtoms, im thinking because i had warped discs before i was gentle with it, since i replaced discs and pads brakes are a1 and now i seem to get this noise, can anyone confirm that disco 3 has the same arms as the rrs on 2005 2,7, just ecp etc seem to list the disco stuff at around 30% cheaper than rrs items, i was going to get bushes as ive access to a press but tbh by the time ive bought a ball joint and the 2 bushes its nearl as cheap as an arm, also struggling to find the arm bush that faces to the front bumper,
Post #404991 Thu Dec 05 2013 6:00pm
sparky8181
Yeah started with a knock when you brake sharp at low speed but quickly got worse and could here same knock when going over bumps, new arms sorted it though and its silent now.
Post #404994 Thu Dec 05 2013 6:31pm
Disco_Mikey
RRS bushes are different. Slightly stronger/firmer than the D3 bushes.
The D3 arms will physically fit though Thumbs Up
Post #405003 Thu Dec 05 2013 7:29pm
shadrack
il just get rrs ones then, just thought it might be a scam trying to get more money from rrs owners
Post #405017 Thu Dec 05 2013 10:18pm
