| RRSPORT.CO.UK | ||
|  | Home > Technical > Multiple Warning Lights |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Have you replaced a brake light bulb lately   | ||
|  Thu Nov 14 2013 11:47am |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Just checked the brake lights and they are fine.  | ||
|  Thu Nov 14 2013 11:58am |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Do the faults clear if you switch the ignition off then back on again   | ||
|  Thu Nov 14 2013 12:04pm |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | The suspension lowered and air suspension indicator turn on after a few seconds of starting/driving.
|  Thu Nov 14 2013 12:13pm |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324      | Brake light switch. Sits above the brake pedal. Access through removing the lower panel. £18. I had the same issue. | ||
|  Thu Nov 14 2013 3:39pm |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Would the brake lights work as normal if the brake like switch has gone? | ||
|  Thu Nov 14 2013 3:47pm |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324      | Yes. Well they did on mine. Have a close look at the switch because you can sometimes see the burn marks. It just gets old and gives up resulting in these lights coming on. | ||
|  Thu Nov 14 2013 8:13pm |
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280      | +1 on the brake light switch. I had the same problem at the weekend. Sorted by replacing the switch and following Paddi's guide here http://www.rrsport.co.uk/forum/topic30757.html
|  Thu Nov 14 2013 10:03pm |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Thanks for the reply guys. I will have a go this weekend and let you know how I get on. | ||
|  Fri Nov 15 2013 10:28am |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Quick update. Changed the brake light switch and still no change.  | ||
|  Sun Nov 17 2013 2:19pm |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324      | Battery in tip top condition? Again a weak battery can cause some warnings to come up. Next step would be get it plugged and see what codes you have stored and take it from there. | ||
|  Sun Nov 17 2013 7:08pm |
| jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85  | Could be something to do with the electrics related to the towhook.
|  Mon Nov 18 2013 7:43am |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23  | Okay guys. The car is in with a specialist.
|  Tue Nov 19 2013 2:08pm |
| Posting Rules
 Or have you got a brake light bulb that has failed
 . I haven't replaced a bulb recently either.
