![]() | Home > Technical > Multiple Warning Lights |
Have you replaced a brake light bulb lately |
| norman1979 Member Since: 24 Apr 2013 Location: London Posts: 23 |
Just checked the brake lights and they are fine. |
Do the faults clear if you switch the ignition off then back on again |
The suspension lowered and air suspension indicator turn on after a few seconds of starting/driving.
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324
Brake light switch. Sits above the brake pedal. Access through removing the lower panel. £18. I had the same issue. |
Would the brake lights work as normal if the brake like switch has gone? |
Yes. Well they did on mine. Have a close look at the switch because you can sometimes see the burn marks. It just gets old and gives up resulting in these lights coming on. |
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280
+1 on the brake light switch. I had the same problem at the weekend. Sorted by replacing the switch and following Paddi's guide here http://www.rrsport.co.uk/forum/topic30757.html
Thanks for the reply guys. I will have a go this weekend and let you know how I get on. |
Quick update. Changed the brake light switch and still no change. |
Battery in tip top condition? Again a weak battery can cause some warnings to come up. Next step would be get it plugged and see what codes you have stored and take it from there. |
| jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
Could be something to do with the electrics related to the towhook.
Okay guys. The car is in with a specialist.
| All times are GMT |
