Home > General > Drivers side of car - Soaked.
Page 2 of 3 <123>
PEACHY
Will do me old pal - car will be put in a garage tomoz & wont leave until its waterproof Laughing Thumbs Up put new Black handles & black & silver side vents on today with the black & silver front grill -looks nice Thumbs Up If you need AB grill & vents - yours for a song ( mates rates ) OEM Thumbs Up
 16MY Estoril Blue SVR.............
Post #401028 Sun Nov 03 2013 10:31pm
PEACHY
mse wrote:
Start with the simple things then move to the more complex.
Have you sunroofs are the ac drains unblocked and are all the door seals seated properly and making good contact.
Water doesn't flow uphill.
Getting the trim away from the rear windows is simple 5 minutes, fire a hose at it to see if it's that
Will do - Thanks Mike Thumbs Up 16MY Estoril Blue SVR.............
Post #401029 Sun Nov 03 2013 10:34pm
mse
just made the message make a bit more sense Embarassed Mike
2014 Facelift Discovery
Post #401031 Sun Nov 03 2013 11:17pm
PEACHY
Update - changed the tailgate rubber - checked the front drain holes on the sunroof - they are draining ok - the back drain holes are not Sad does anybody have any idea how they travel through the car ?
I used to park my car on the drive facing downhill - no problems - since I had my spare stolen I now park it the other way round so the Blackvue can record the street not my house. This means any water that is getting into the sunroof is running to the rear drain pipes Idea
I have looked on the D3 Site ( they are good - very good Whistle ) but cant seem to find anything to help - there is the idea of running net curtain wire through the pipe but I am concerned I may dislodge any fittings.
Any ideas Bow down 16MY Estoril Blue SVR.............
Post #401636 Sun Nov 10 2013 4:20pm
flack
The back ones are behind the D pillar and travel down through to the bottom of the car, you nee to remove the D pillars to gain access to them.
Flack Thumbs Up
Post #401637 Sun Nov 10 2013 5:04pm
PEACHY
Thanks flack - the interior D Pillar trim ? Bow down do you know where they exit the car ? Thumbs Up 16MY Estoril Blue SVR.............
Post #401638 Sun Nov 10 2013 5:14pm
flack
The one on the drivers side should exit the bottom of the car with the fuel filler cap drains, the other side will be in the same place, I would just gently push a curtain wire down from the top first and then see if you can see water dripping down at the rear of the car.
Flack Thumbs Up
Post #401640 Sun Nov 10 2013 5:20pm
PEACHY
Thanks mate - much appreciated I will try that next Thumbs Up 16MY Estoril Blue SVR.............
Post #401641 Sun Nov 10 2013 5:22pm
RRS Daz
I hope this goes well for you and you decide to keep that sport Thumbs Up
Post #401644 Sun Nov 10 2013 7:38pm
mse
Glad it's down to the sun roofs guessed that might be the case.
Have you got access to a compressor? Blow air up or down the pipe. This will clear it quickly Mike
Post #401647 Sun Nov 10 2013 8:16pm
rigsby
Hi Peachy, sorry you are having trouble mate, hope you get it sorted.
PS Your Sport is a cracker mate, make any decision to get rid of it with a clear head, its not something to rush and then regret. Good Luck
Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #401654 Sun Nov 10 2013 9:33pm
simple1
Sounds like you have SAD Peachy. Withdrawals from washing maybe.
I have been through all the emotional ups and downs but still ended up keeping the car! Whistle
Go buy a £500 bit of shrapnel and park it with keys in, it'll still be there in the morning Rolling with laughter
My Fullfat got hit in work the other day by employee in a 350 quid mondeo and he didn't say a word even though he was well aware he had done it. CCTV caught him and yes bumper paint coming out of his pay packet. I park my L200 everywhere, it's filthy dirty and no one goes within 10 feet of it. Just doesn't give the same pleasure driving about. Thumbs Up
Looked at an Alfa 159 sport wagon today as a cheaper smoke with a bit of performance, not sure if I wouldn't be jumping out of the pot into the fire with regards to reliability Rolling with laughter Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #401660 Sun Nov 10 2013 10:29pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I had this problem with my 07 once and never got to the bottom of it, but it has never happened again. There was a Technical Bulletin issued by Land Rover for the earlier models for an amendment of the A pillar if you can get hold of it..good luck.. Also no sunroof in mine to cause confusion..
Post #401677 Mon Nov 11 2013 9:22am
Paddi
Hi Peachy,
Just another post to offer support and solidarity! Stick with it - water leaks are annoying but not the end of the world.
If it makes you feel any better I came back to the car after having been out for a good run yesterday and found the dreaded heavy condensation on the inside of the windscreen. Quick check revealed soaking wet front passenger carpet. Big Cry
Closer look this morning shows water dripping from the bottom edge of the lower glovebox. Found a TSB on loose fitting plenum chamber cover allowing water into pollen filter so hopefully that's it. Biggest hassle might be drying everything out. 2008 MY Java Black TDV8 HSE
Post #401683 Mon Nov 11 2013 11:44am
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
Where did you get the black door handles peachy ?
Cheers Bob
Post #401689 Mon Nov 11 2013 12:53pm
Page 2 of 3 <123>
