![]() | Home > General > Drivers side of car - Soaked. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Will do - Thanks Mike ![]() 17MY Autobiography Dynamic - Corris Grey - WOW. 14MY Autobiography Dynamic - SDV6 - Fuji White ![]() 12MY Autobiography - SDV6 - Santorini Black - Dual View - Rear Entertainment - Sunroof. 12MY Autobiography - SDV6 - Orkney Grey - awesome ;( 2005 Java Black - 4.2 V8 Supercharged First Edition- will never be forgotten ;( |
just made the message make a bit more sense |
Update - changed the tailgate rubber - checked the front drain holes on the sunroof - they are draining ok - the back drain holes are not |
The back ones are behind the D pillar and travel down through to the bottom of the car, you nee to remove the D pillars to gain access to them.
Thanks flack - the interior D Pillar trim ? |
The one on the drivers side should exit the bottom of the car with the fuel filler cap drains, the other side will be in the same place, I would just gently push a curtain wire down from the top first and then see if you can see water dripping down at the rear of the car.
Thanks mate - much appreciated I will try that next |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
I hope this goes well for you and you decide to keep that sport |
Glad it's down to the sun roofs guessed that might be the case.
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Hi Peachy, sorry you are having trouble mate, hope you get it sorted.
Sounds like you have SAD Peachy. Withdrawals from washing maybe.
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I had this problem with my 07 once and never got to the bottom of it, but it has never happened again. There was a Technical Bulletin issued by Land Rover for the earlier models for an amendment of the A pillar if you can get hold of it..good luck.. Also no sunroof in mine to cause confusion.. |
Hi Peachy,
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
Where did you get the black door handles peachy ? Cheers Bob |
