| RRSPORT.CO.UK | ||
|  | Home > Technical > Dynamic Response |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | My 07 never had it. 07MY RRS TDV6
|  Sun Nov 03 2013 11:03am |
| Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154      | Both  MY08 and MY10 TDV8 we had previously had it fitted. The supercharged still has it (mate has an AB). I would have thought though that the up spec SDV6 would have come with it, apparently this doesn't seem to be the case. Wonder if they fitted it to any of the V6's? And yes on the MY10 it started clunking, though it was  fixed. SWMBO owns this car I get to drive occasionally  | ||
|  Mon Nov 04 2013 3:48am |
| codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171      | It WAS fitted to the V6 HSEs, but not the SE, afaik you has to select it every time you went for a drive, I have never tried it myself so can comment on if it is any better. I find the 'standard' settings on mine more than enough!
|  Mon Nov 04 2013 6:19am |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | We do not have HSEs and SEs etc in Australia.  Trim and equipment levels go with fitted engines.  The TDV6 has base level trim and the Supercharged V8 the highest with the V8 and TDV8 fitting in between.  However all cars can be optioned to higher levels over base trim and equipment levels.
|  Mon Nov 04 2013 6:36am |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | Strange your experience is the opposite of mine - MY10 TDV6 I had did not have it but my Black Edition SDV6 does  | ||
|  Mon Nov 04 2013 8:15am |
| Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154      | I  was told by JLR "active cornering enhancement is no longer available." Which while not a bad thing was somewhat surprising.  So wondered when/where it quietly went away. SWMBO owns this car I get to drive occasionally  | ||
|  Mon Nov 04 2013 9:52am |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Odd they deleted from the Oz spec. Its a good option I thought, Mike
|  Mon Nov 04 2013 5:48pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Maybe they found it too unreliable in Oz conditions? 2012 SDV6 - it's missing a couple of cylinders
|  Mon Nov 04 2013 7:42pm |
| Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154      | Possible. Most I speak to that have it have had issues with the dreaded knocking. All fixed but all under warranty. Must have cost JLR a fortune for all the repair work. I see that this is available on the 2014 RRS so perhaps they have more confidence in it now? Given that this is what the 3rd gen, the first being the ACE in the Disco 2 (which I understand also gave problems) SWMBO owns this car I get to drive occasionally  | ||
|  Mon Nov 04 2013 8:51pm |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644    | I have owned 2 D2's -1 with ACE and 1 without and I definitely knew which had it  | ||
|  Mon Nov 04 2013 9:14pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Get on an autobahn or motorway and stick it on when your cruising - that's when I used it most Mike
|  Mon Nov 04 2013 9:16pm |
| Posting Rules
 Just curious about when JRL stopped fitting this.
 ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
