![]() | Home > Technical > Dynamic Response |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071
My 07 never had it. 07MY RRS TDV6
| Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154
Both MY08 and MY10 TDV8 we had previously had it fitted. The supercharged still has it (mate has an AB). I would have thought though that the up spec SDV6 would have come with it, apparently this doesn't seem to be the case. Wonder if they fitted it to any of the V6's? And yes on the MY10 it started clunking, though it was fixed. SWMBO owns this car I get to drive occasionally |
| codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171
It WAS fitted to the V6 HSEs, but not the SE, afaik you has to select it every time you went for a drive, I have never tried it myself so can comment on if it is any better. I find the 'standard' settings on mine more than enough!
We do not have HSEs and SEs etc in Australia. Trim and equipment levels go with fitted engines. The TDV6 has base level trim and the Supercharged V8 the highest with the V8 and TDV8 fitting in between. However all cars can be optioned to higher levels over base trim and equipment levels.
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
Strange your experience is the opposite of mine - MY10 TDV6 I had did not have it but my Black Edition SDV6 does |
I was told by JLR "active cornering enhancement is no longer available." Which while not a bad thing was somewhat surprising. So wondered when/where it quietly went away. SWMBO owns this car I get to drive occasionally |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Odd they deleted from the Oz spec. Its a good option I thought, Mike
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9158
Maybe they found it too unreliable in Oz conditions? 2012 SDV6 - it's missing a couple of cylinders
Possible. Most I speak to that have it have had issues with the dreaded knocking. All fixed but all under warranty. Must have cost JLR a fortune for all the repair work. I see that this is available on the 2014 RRS so perhaps they have more confidence in it now? Given that this is what the 3rd gen, the first being the ACE in the Disco 2 (which I understand also gave problems) SWMBO owns this car I get to drive occasionally |
I have owned 2 D2's -1 with ACE and 1 without and I definitely knew which had it |
Get on an autobahn or motorway and stick it on when your cruising - that's when I used it most Mike
| All times are GMT |
