Home > Technical > Help and advice needed
Tigerdon
Northern Ireland 2006 Range Rover Sport Supercharged Java Black
As of late I have been having horrendous problems with my RRS SC
Alternator
Starter
2 cats needing replaced
Suspension compressor going
And now I've had the following 2 problems
Last Sunday whilst driving the car came up with a transmission fault and went into F mode
Turned it on and off and it cleared (at this time the suspension amber light was on. Normal height only)
This transmission fault didn't happen again however As a result I had tranny oil and filter changed.
Just tonight on a short journey the engine revs started to fluctuate from approx 1500-1750-2000 at a constant speed
Ie I had foot with constant pressure on accessor but rev counter and engine was going up and down like crazy
I've a video of it but can't post it with iPad
Any ideas guys
I'm at end of my tether with this car now
Post #400997 Sun Nov 03 2013 7:29pm
PEACHY
& I thought I had it bad Big Cry sorry to hear of your constant problems - had a similar fault - it was a cheap fix - a temp sensor in the coolant hose Thumbs Up ( I've changed EAS compressor & battery & alternator ).
When they are good they are Censored amazing when they are s--t - they are absolutely s--t.
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #400998 Sun Nov 03 2013 7:35pm
Tigerdon
Big time my problem is I've had very few opportunities past while to say it's anything apart from dung
I hope that is problem but with me and this thing I can't see any chance it's a quick fix
£4000 spent past 2 months and still running like a dog
Post #401002 Sun Nov 03 2013 7:58pm
Paddi
Fluctuating revs can be a sign of torque converter on the way out but before jumping to that conclusion and bearing in mind the other suspension issues I'd start with having the fault codes read and check some of the usual suspects like brake light bulbs and brake light switch. 2008 MY Java Black TDV8 HSE
Post #401018 Sun Nov 03 2013 9:37pm
Tigerdon
But there are no codes showing mate
Post #401020 Sun Nov 03 2013 9:44pm
Paddi
So you have plugged in a LR specific diagnostic fault code reader and there are no faults logged right? 2008 MY Java Black TDV8 HSE
Post #401056 Mon Nov 04 2013 12:35pm
Tigerdon
Was up at Indy specialist today they said its a transmission fault
Apparently there is some additive they can put in that can sort it out but if not it's a new gear box I'm afraid
Post #401058 Mon Nov 04 2013 12:39pm
Paddi
What fault codes if any did they find that points to a gearbox fault?
The fluctuating revs can be a sign of a torque converter lock up clutch worn but there is usually vibration too. The torque converter is a separate unit incorporating the lock up clutch and can be changed. Just had mine changed for total cost of about £1,400 incl parts, ATF and labour. Perhaps try to find a really good transmission specialist in your area and get them to have a look at it?
The additive your indy referred to is probably a friction modifier similar to or the same as 'Dr Tranny' made by 'LUBEGUARD'. It's probably worth giving it a try. If the symptoms improve then it at least acts as a diagnostic suggesting the torque converter. 2008 MY Java Black TDV8 HSE
Post #401064 Mon Nov 04 2013 1:17pm
Tigerdon
Yes it's Dr Tranny the additive they referred to
Hoping and praying that works r according to them it's a a new box
But if I could get away with torque Convertor it's the definite lesser of 2 evils
Post #401078 Mon Nov 04 2013 3:28pm
Tigerdon
Were can u change the torque Convertor only? I've been told it can't be bought as a separate unit
Thanks
Post #401083 Mon Nov 04 2013 4:12pm
Paddi
Oh yes they can; because I've just had one fitted Smile
Specialists with the right equipment can refurb the TC but because they can buy new ones for about £450 its not worth bothering it seems.
They are supplied by ZF from Belgium but that's as much as I know. 2008 MY Java Black TDV8 HSE
Post #401091 Mon Nov 04 2013 6:49pm
Tigerdon
I should know tomorrow if this Dr Tranny works r not
Also when the guy from the Indy specialist took it for a run today he said it was vibrating also. So u is prob right in respect to the TC
Who Paddi did yours for u r does any1 know any one in Northern Ireland that can do this ?
Regards
Post #401092 Mon Nov 04 2013 7:00pm
Paddi
Replied to your PM.
Mine was done by Stephens Engineering in Hertfordshire. http://www.stephensengineering.co.uk/
My RRS had an unusual problem and after much consulting of specialists none of them could be certain it was the TC but thought it was the most likely culprit. Took the chance of changing it and guess what...... its still the Censored same Big Cry .
I'll post a separate thread on this saga for you all to laugh at later. 2008 MY Java Black TDV8 HSE
Post #401094 Mon Nov 04 2013 7:28pm
Tigerdon
What was up with yours fella?
Post #401095 Mon Nov 04 2013 7:35pm
drdelrrs
You could always try a auto-box stall test.
i.e. Left foot hard on brake, select Drive and slowly increase the revs. The TC and gearbox should be able absorb the engine's power and stall (hold) it at stable revs.
Don't hold the revs for too long; 15-20 seconds.
It the revs continue to rise but the gearbox is quiet its probably the TC or if there are strange noises there's a chance the brake bands in the gearbox are shot or need adjusting.
Post #401150 Tue Nov 05 2013 12:36pm
