![]() | Home > Technical > Help and advice needed |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
& I thought I had it bad |
Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35 ![]() ![]() ![]() |
Big time my problem is I've had very few opportunities past while to say it's anything apart from dung
Fluctuating revs can be a sign of torque converter on the way out but before jumping to that conclusion and bearing in mind the other suspension issues I'd start with having the fault codes read and check some of the usual suspects like brake light bulbs and brake light switch. 2008 MY Java Black TDV8 HSE
But there are no codes showing mate |
So you have plugged in a LR specific diagnostic fault code reader and there are no faults logged right? 2008 MY Java Black TDV8 HSE
Was up at Indy specialist today they said its a transmission fault
What fault codes if any did they find that points to a gearbox fault?
Yes it's Dr Tranny the additive they referred to
Were can u change the torque Convertor only? I've been told it can't be bought as a separate unit
Oh yes they can; because I've just had one fitted |
I should know tomorrow if this Dr Tranny works r not
Replied to your PM.
What was up with yours fella? |
You could always try a auto-box stall test.
