![]() | Home > Technical > Whistle and Misfiring. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
The usual advice at this stage is to check the intercooler hoses for splits or other damage. They are the two big ones right at the top/front of the engine bay looking like radiator hoses. They are a relatively cheap item to replace if they do show any damage. 2012 SDV6 - it's missing a couple of cylinders
As has been said - check the hoses associated with the turbos; there are two more short 'L' shaped ones under the engine acoustic cover (my local LR dealer says these short ones are a common issue but I've never seen a post about them on this forum!).
07RRSTDV8 Member Since: 30 Oct 2013 Location: south east Posts: 13 ![]() ![]() ![]() |
Ok I'll try that first, are you suggesting those for the whistling noise or the misfiring? Or a combo of both? |
Whistling noise particularly. Maybe if there is a big enough leak it could cause a misfire but TBH I don't know. Usually people report black exhaust smoke on acceleration and some loss of power when a hose is leaking. 2008 MY Java Black TDV8 HSE ![]() |
Ok thanks for the help. My garage is waiting on a two post ramp to be installed, but looks like it could be two more weeks before its fitted and he can lift the body. I know it's possible to remove the pass side head off with the body still on.
Sorry but I don't know the answer to that question. Hopefully someone who does know might be along soon to advise you. 2008 MY Java Black TDV8 HSE
Anyone know if drivers side head can be removed with body on? |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
body off is an easy job
