![]() | Home > Technical > Advice on Sloppy Gear Change and a Clunk Please? |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
The car is an 06 with 43k miles.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4502 ![]() ![]() ![]() |
You need to get in touch with geoff, on the D3 forum. http://www.disco3.co.uk/forum/topic100717.html
How does that differ having it changed the conventional way? |
The Megaflush changes around 98% of the oil in the gearbox, as it uses the gearbox oil pump to flush it all out., changing the oil in the torque convertor too.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
You should definitely notice the response and higher revving between gear changes using sport mode. I would do 2 things, change the tranny oil as suggested then go to an LR dealer and get the latest software upgrades. The clunk you experience is not unusual but should not be too pronounced. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
There are centres around the UK who can carry this out, here is a link |
Not sure where I read it, Could have been on here, the Disco 3/4 forum, or possibly one of the BMW forums, however I am sure I read that there is "anti thump / anti clonk" software fix the ZF box. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Scroll down until you see Flacks response
Is it wise to change the oil without changing the filter?
He mentioned V8's, this is a diesel HSE and not a V8. However, the problem described is exactly as that chap said, I also felt like it is pulling away in second. Is that normal? |
Cheers, I have contacted them to ask where the nearest place is. Failing that, Ill have to ask that bloke on the Disco forum when he is next heading north. |
V8 / V6 all the same gearbox ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Does anybody have a price on this megaflush, as I was going to take mine to a local indie, as the car has done nearly 100,000 miles 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
As you are only in Wigan, Preston is just up the road: http://www.rrsport.co.uk/forum/topic33439.html |
Mines a 3.6v8 mate, he is not flushing them |
