Home > Technical > Advice on Sloppy Gear Change and a Clunk Please?
Stuart
The car is an 06 with 43k miles.
There is nothing to suggest the mileage isn't right going off condition and general feel. No warning lights on.
I have a couple of issues with the gearbox, but being as this is my first RRS, some of it may be just me, or normal, so better to ask I thought.
When I lift off the accelerator, and back on again (as you do in traffic for example) I occasionally feel a mild clunk as the drive catches again. Were it an old van, you might say like a prop donut or UJ worn. Pretty irritating though.......
I don't notice much difference between regular 'drive' and the left shift into 'sport'. If any. Should the difference be noticeable?
In the morning, when cold, when I go to pull away, I have to bury my foot into the carpet to get it to move away at a decent lick. Only when its cold though, not an issue when its warm. However, that said, when I want to nip on a roundabout quickly for example, there is only what I can describe as turbo lag. Just a moment of nothing between plonking your right foot down and movement.
The gear change to me feels a bit sloppy; or badly timed might be a better description. While the kick down works OK, it doesn't feel as responsive as I think it should.
I was reading here tonight that there are some software updates that would have been done if it was serviced at the dealer. It had I think a 6k service at the dealer, and after that it was done at a local garage somewhere in the sticks.
Would software updates sharpen the gear change?
Any thoughts on the transmission clunk?
Post #398798 Fri Oct 18 2013 12:52am
Disco_Mikey
You need to get in touch with geoff, on the D3 forum. http://www.disco3.co.uk/forum/topic100717.html
He has a fancy machine to change the autobox oil. Makes a huge difference to the car. He is mobile, and regularly travels with his machine Thumbs Up
Post #398837 Fri Oct 18 2013 6:52am
Stuart
How does that differ having it changed the conventional way?
Post #398871 Fri Oct 18 2013 12:21pm
Disco_Mikey
The Megaflush changes around 98% of the oil in the gearbox, as it uses the gearbox oil pump to flush it all out., changing the oil in the torque convertor too.
A conventional drain and refill only does 40-50% of the old oil
Post #398878 Fri Oct 18 2013 12:45pm
BKHK
You should definitely notice the response and higher revving between gear changes using sport mode. I would do 2 things, change the tranny oil as suggested then go to an LR dealer and get the latest software upgrades. The clunk you experience is not unusual but should not be too pronounced. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #398887 Fri Oct 18 2013 1:36pm
MXSRR
England 2007 Range Rover Sport TDV8 HSE Sumatra Black
There are centres around the UK who can carry this out, here is a link Thumbs Up
You will need to contact them through the contact enquiry as the postcode/town search is not up and running yet.
http://www.wynnsservicecentres.co.uk/transmission.php MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's
Post #398888 Fri Oct 18 2013 1:39pm
SRE
Spain
Not sure where I read it, Could have been on here, the Disco 3/4 forum, or possibly one of the BMW forums, however I am sure I read that there is "anti thump / anti clonk" software fix the ZF box. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #398901 Fri Oct 18 2013 2:28pm
SRE
Spain
Scroll down until you see Flacks response
http://www.rrsport.co.uk/forum/topic9668.h...p;start=45 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #398902 Fri Oct 18 2013 2:38pm
Stuart
Is it wise to change the oil without changing the filter?
It likely doesn't need a change because of miles, but it is seven years old?
Post #398907 Fri Oct 18 2013 2:57pm
Stuart
He mentioned V8's, this is a diesel HSE and not a V8.
However, the problem described is exactly as that chap said, I also felt like it is pulling away in second. Is that normal?
Post #398908 Fri Oct 18 2013 2:58pm
Stuart
Cheers, I have contacted them to ask where the nearest place is.
Failing that, Ill have to ask that bloke on the Disco forum when he is next heading north.
Post #399228 Mon Oct 21 2013 12:05am
SRE
Spain
V8 / V6 all the same gearbox Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #399240 Mon Oct 21 2013 9:05am
shakeapaw
Does anybody have a price on this megaflush, as I was going to take mine to a local indie, as the car has done nearly 100,000 miles 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #400745 Fri Nov 01 2013 5:13am
Stuart
As you are only in Wigan, Preston is just up the road: http://www.rrsport.co.uk/forum/topic33439.html
Post #400750 Fri Nov 01 2013 8:40am
shakeapaw
Mines a 3.6v8 mate, he is not flushing them Sad 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #400830 Fri Nov 01 2013 7:32pm
