Home > For Sale & Wanted > [Wanted] New FBH needed
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi, Just installed a remote on my FBH but the heater only starts and then stops again. Tried to flush it several times but no luck. Anyone got a used one that can be shipped to Norway? RRS 2006 2.7 HSE
Post #395389 Wed Sep 18 2013 4:45pm
camel_landy
What's your ambient temperature at the moment? If it's above 5 degrees, IIRC that's exactly what the FBH should do.
M
Post #395433 Wed Sep 18 2013 11:16pm
RRSNorway
? Shocked english please..Smile
I only know that my local dude said it was no use trying to fix it and I needed to change the FBH. RRS 2006 2.7 HSE
Post #395634 Fri Sep 20 2013 11:22pm
flack
If you can get the software and a lead to connect to the FBH you can then test it fully, I have had a few like this and with a diagnostic lead and the webasto software have manged to clear them and get them going, can also be done with a Faultmate MSV2.
Flack Thumbs Up
Post #395654 Sat Sep 21 2013 8:51am
Look on the Disco3 wiki. There's a section about the FBH including where to source the leads and software. 2012 SDV6 - it's missing a couple of cylinders
Post #395662 Sat Sep 21 2013 9:17am
camel_landy
Laughing
The initial question is: 'What is the temperature in your location at the moment?'
IIRC - The heater isn't supposed to start if the temperature is >5 degrees.
So, if it's warm enough, it's not supposed to start anyway.
As for fixing them, if you can work out what's wrong, they're fairly easy to repair and the parts are usually available on e-bay, etc...
M
Post #395703 Sat Sep 21 2013 6:32pm
RRSNorway
its now 2 degress here in Oslo and the FBH should start. We tried to get it going with the faultmate and it starts but stops again every time.
Must be the burningchamber? RRS 2006 2.7 HSE
Post #398386 Mon Oct 14 2013 11:20pm
Marsie
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Not sure the temperature matters if fitted with a remote as this overrides the limits for auto operation . I fitted an oval timer to my D3 and it would fire up whenever i pressed the flame button regardless of outside temperature. The >4/5 degrees setting only comes into effect for automatic operation as does coolant temp and fuel level
Here is the info on the D3 site that RRSTDV8 suggested,hopefully it may help?
http://www.disco3.co.uk/wiki/Fuel_Burning_Heater
Paul Thumbs Up
Post #398481 Tue Oct 15 2013 9:04pm
camel_landy
Apologies, I missed your reply! Embarassed
Yes, it could be the chamber but worth checking that the fuel pump/supply is working, coolant circulation pump and the fan/air supply for the chamber are all working before replacing.
M
Post #398494 Tue Oct 15 2013 10:34pm
RRSNorway
had a local guy test the FBH and he said its 90% the burming chamber.
where can I get a used one for a good price? RRS 2006 2.7 HSE
Post #399373 Mon Oct 21 2013 11:26pm
camel_landy
E-Bay is probably your best bet.
M
Post #399483 Tue Oct 22 2013 6:57pm
