| RRSPORT.CO.UK | ||
|  | Home > For Sale & Wanted > [Wanted] New FBH needed |
| camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68    | What's your ambient temperature at the moment? If it's above 5 degrees, IIRC that's exactly what the FBH should do.
|  Wed Sep 18 2013 10:16pm |
| RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314      | ?   | ||
|  Fri Sep 20 2013 10:22pm |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379  | If you can get the software and a lead to connect to the FBH you can then test it fully, I have had a few like this and with a diagnostic lead and the webasto software have manged to clear them and get them going, can also be done with a Faultmate MSV2.
|  Sat Sep 21 2013 7:51am |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Look on the Disco3 wiki. There's a section about the FBH including where to source the leads and software. 2012 SDV6 - it's missing a couple of cylinders
|  Sat Sep 21 2013 8:17am |
   The initial question is: 'What is the temperature in your location at the moment?' IIRC - The heater isn't supposed to start if the temperature is >5 degrees. So, if it's warm enough, it's not supposed to start anyway. As for fixing them, if you can work out what's wrong, they're fairly easy to repair and the parts are usually available on e-bay, etc... M | ||
|  Sat Sep 21 2013 5:32pm |
| RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314      | its now 2 degress here in Oslo and the FBH should start. We tried to get it going with the faultmate and it starts but stops again every time.
|  Mon Oct 14 2013 10:20pm |
| Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376      | Not sure the temperature matters if fitted with a remote as this overrides the limits for auto operation . I fitted an oval timer to my D3 and it would fire up whenever i pressed the flame button regardless of outside temperature. The >4/5 degrees setting only comes into effect for automatic operation as does coolant temp and fuel level
|  Tue Oct 15 2013 8:04pm |
 Apologies, I missed your reply!   Yes, it could be the chamber but worth checking that the fuel pump/supply is working, coolant circulation pump and the fan/air supply for the chamber are all working before replacing. M | ||
|  Tue Oct 15 2013 9:34pm |
| RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314      | had a local guy test the FBH and he said its 90% the burming chamber.
|  Mon Oct 21 2013 10:26pm |
| camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68    | E-Bay is probably your best bet.
|  Tue Oct 22 2013 5:57pm |
| Posting Rules
 english please..
 english please..
