Home > General > Possible Detachable Tow Bar Issue
Page 1 of 3 123>
muddywheels
Milk Float Man
Quote:
Detachable tow bars on Discovery 3s become loose due to faulty design. There have been so many reports on various web sites about this issue but no one has done anything to solve the problem. Anyone who has had a failure should report it to VOSA via an online form on their website - this is the government agency that enforce manufacturer recalls. Land Rover are very aware of this fault & VOSA have asked them to solve the issue. So far Land Rover are doing all it can to cover-up the problem & the Customer Relations Manager has told me that he is 'unaware of a problem with this towbar' ever though VOSA acted on it more than a year ago. To fob customers off they have issued a 'wear gauge' to their dealers to measure the free play on the ball in it's mounting. They will regard any ball moving back & forth less than 30mm as 'within tolerance' & refuse any claim. Any ball moving this much would not stay attached to the cross member at all. If everyone with this problem had reported it to VOSA they would have to have issued a recall by now.
I have just read this on a caravan forum and thought I should pass this on as we share the same detachable tow bar. A quick search on google did indeed bring up numerous sites with this mentioned Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397517 Mon Oct 07 2013 3:33pm
Paddi
30 mm ?!! some mistake surely 2008 MY Java Black TDV8 HSE
Post #397529 Mon Oct 07 2013 5:54pm
muddywheels
Milk Float Man
I would of thought 3mm Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397531 Mon Oct 07 2013 5:58pm
This appears to be further evidence of the issue Disco_Mickey raised in another thread. Lots of use results in movement which results in wear. Wear will eventually allow the ball to drop from the housing in the cross member.
In fairness to LR (and I'm surprised to hear myself saying that) they do say in the manual that the quick release ball is not designed for regular use. Or rather they imply it by saying that owners wanting to tow regularly or who want to tow heavier trailers should use the heavy duty system.
If people are using a tow ball on a weekly basis when that ball isn't designed for that usage level and LR actively advise against it then I don't see that they have much to moan about. If you want to tow regularly (and most caravaners will do so presumably) then fit the appropriate tow ball.
I fail to see what LR can do about the QR ball system now. 2012 SDV6 - it's missing a couple of cylinders
Post #397570 Mon Oct 07 2013 10:55pm
SimonR
My feeling is that the wear is caused by abrasion between the parts - and the best way to arrest it is by covering the engagement mechanism with grease! It also makes it much easier to attach / detach!
Granted, you probably don't want an oily-greasy thing in your boot when not in use - but a simple zip-seal freezer bag solves that!
Si
Post #397574 Mon Oct 07 2013 11:10pm
simple1
As most current tow hitch uses a grease free stabilised hitch, introducing grease is not wise.
There have been many reports over the years including a high profile Evo mag editor who lost his £300000 supercar and trailer to a hedge when tow bar came off.
Mine used work loose but I learnt to check it every few hundred miles when towing caravan and was told by LR that the bar was limited to pulling 750kg and that I needed a reinforced version with additional brace to tow 1450kg caravan. Same with car trailer.
Have to same the genuine full fat neck is far better manufactured and secures with more conviction. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #397602 Tue Oct 08 2013 9:40am
muddywheels
Milk Float Man
Simple1 - your post has just scared the Censored out of me Shocked
Are you saying according to LR the detachable below is unsuitable to tow my 1850kg twin axle because that is totally at odds with the description on LR website Confused
Quote:
Part No: LR040247
Lockable for security. Easily removed. For leisure use only. 50mm Tow ball, height 400mm from ground. 3,500kg trailer maximum payload (150kg trailer nose load).
The fixed version would then be necessary and although I think it looks quite at home on a Disco it looks awfull on a sport IMHO Rolling Eyes
Quote:
Part No: LR043271
50mm Tow Ball. Three different towing heights. Lowest tow ball height 350mm from ground. Highest tow ball height 500mm from ground. 3,500kg trailer load capacity (150kg trailer nose load). Required for commercial and constant use only.
Post #397605 Tue Oct 08 2013 9:57am
It looks a lot better than seeing your £20k (or whatever they cost) caravan veering off in to a hedge on its own...
...although to my eye, the "proper" tow bar looks pretty good and gives the RRS a purposeful look (which is rather contrary to the look most want with their big wheels etc. I suppose Whistle Rolling with laughter ) 2012 SDV6 - it's missing a couple of cylinders
Post #397616 Tue Oct 08 2013 10:43am
simple1
Paul
The bottom one is the one I believe you need but agree they look terrible. The neck is removable if you want to crawl about undoing bolts but defeats the purpose. My concern that the tow neck actually can come off even when locked on was a worry.
Having checked I believed the original neck was ok but seems LR get out clause is 750kg or maximum of 50kg nose weight which a well loaded caravan should not exceed Laughing yea right. That's why you have self levelling suspension I thought Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #397618 Tue Oct 08 2013 10:50am
muddywheels
Milk Float Man
My 2 previous D2's had the heavy duty tow bar and apart from my bruised shins I felt it complemented the beasts Twisted Evil
Until Simon posted is comment I wasn't worried being well within the 150kg/3500kg limit posted on the LR website Shocked
I hate big wheels and bling on a RRS but like the idea of hiding the tow bar when not using it - sport styling and a dirty big girder strapped on the back just looks wrong to me Rolling Eyes
Simon - if you are correct - trading standards may be interested in this I feel - you can not claim 150/3500kg then say 50/750 afterwards Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397621 Tue Oct 08 2013 11:09am
SimonR
Are you sure? The only reference to this in the documentation I can find is:
"The towing hitch must be kept clean and greased. However if a stabilisation device is used, the towing hitch must be free from grease"
This is referring to the ball, not the engagement mechanism - as the stabilised hitches work by gripping the ball tightly to damp out oscillations. Obviously, if it's greased, it will not work.
I, however was referring to the engagement between the tow bar and the vehicle.
The two parts are not intended to jam together by friction - it's a wedge being pushed in to a tapered hole with a locking pin to keep them engaged. The pin can only drop fully in to it's socket if the wedge fully engages.
That leaves two options. 1. Lubricate it to keep the surfaces corrosion free or 2. use a hammer to make sure you get full engagement.
If yours is working loose every few hundred miles, it would suggest it was not engaged properly in the first place, or it has suffered too much wear / corrosion that it cannot engage properly.
Si
Post #397625 Tue Oct 08 2013 11:20am
Martin
Site Administrator & Owner
Lots about this on DISCO3 Smile Like this site? Buy some RRSPORT goodies to show your support!
Post #397636 Tue Oct 08 2013 11:37am
muddywheels
Milk Float Man
Considering grease is likely to transfer by its nature I have also avoided greasing the detachable components to protect my caravan stabiliser Thumbs Up
Presumably if inserted correctly then it can be locked and the key can be removed - if not the key can not be locked and removed - therefore if the key is removed it is fully engaged so should not work loose Confused
If you need a hammer to fit then you have a problem and should not be towing with it - hammer is only for removing when left overnight or more Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397637 Tue Oct 08 2013 11:43am
simple1
Mine came loose when locked and key was removed but never became detached but coming anything isn't good. Might be a case then that bod as LR didn't know what they were talking about but did continue using standard neck just checked it was fully engaged all the time. I know in evo's case LR claimed bar wasn't inserted fully even though key was removed. The stop strap did its job and stopped the trailer before it did any damage.
Like muddy, I would keep grease away from all of it as would end up on ball if you use stabiliser. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #397641 Tue Oct 08 2013 12:20pm
simonsti
England 2013 Range Rover Sport SDV6 HSE Nara Bronze
I tow a horse box every week and the towball does loosen over a journey, it also does not seem to lock solid at all like it used too so I am assuming it has worn over time. Towing a 6 berth Elddis in August caused it to loosen a worrying amount after a 200 mile journey. 2014 Nara Bronze SDV6
GONE TDV6 HSE RRS in Giverny green,Ebony interior, Side steps,Tints, PTI, Tow pack, mud flaps, Side strips and Dynamics pack.
Post #397644 Tue Oct 08 2013 12:44pm
Page 1 of 3 123>
