![]() | Home > General > Possible Detachable Tow Bar Issue |
30 mm ?!! some mistake surely 2008 MY Java Black TDV8 HSE
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
I would of thought 3mm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9083 ![]() ![]() ![]() |
This appears to be further evidence of the issue Disco_Mickey raised in another thread. Lots of use results in movement which results in wear. Wear will eventually allow the ball to drop from the housing in the cross member.
SimonR Member Since: 29 Sep 2013 Location: Horsham Posts: 25 ![]() ![]() ![]() |
My feeling is that the wear is caused by abrasion between the parts - and the best way to arrest it is by covering the engagement mechanism with grease! It also makes it much easier to attach / detach!
As most current tow hitch uses a grease free stabilised hitch, introducing grease is not wise.
Simple1 - your post has just scared the
The fixed version would then be necessary and although I think it looks quite at home on a Disco it looks awfull on a sport IMHO ![]()
Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW Still hoping for a S2 one day! |
It looks a lot better than seeing your £20k (or whatever they cost) caravan veering off in to a hedge on its own...
Paul
My 2 previous D2's had the heavy duty tow bar and apart from my bruised shins I felt it complemented the beasts ![]() Until Simon posted is comment I wasn't worried being well within the 150kg/3500kg limit posted on the LR website ![]() I hate big wheels and bling on a RRS but like the idea of hiding the tow bar when not using it - sport styling and a dirty big girder strapped on the back just looks wrong to me ![]() Simon - if you are correct - trading standards may be interested in this I feel - you can not claim 150/3500kg then say 50/750 afterwards ![]() Still hoping for a S2 one day! |
Are you sure? The only reference to this in the documentation I can find is: "The towing hitch must be kept clean and greased. However if a stabilisation device is used, the towing hitch must be free from grease" This is referring to the ball, not the engagement mechanism - as the stabilised hitches work by gripping the ball tightly to damp out oscillations. Obviously, if it's greased, it will not work. I, however was referring to the engagement between the tow bar and the vehicle. The two parts are not intended to jam together by friction - it's a wedge being pushed in to a tapered hole with a locking pin to keep them engaged. The pin can only drop fully in to it's socket if the wedge fully engages. That leaves two options. 1. Lubricate it to keep the surfaces corrosion free or 2. use a hammer to make sure you get full engagement. If yours is working loose every few hundred miles, it would suggest it was not engaged properly in the first place, or it has suffered too much wear / corrosion that it cannot engage properly. Si |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Lots about this on DISCO3 |
Considering grease is likely to transfer by its nature I have also avoided greasing the detachable components to protect my caravan stabiliser |
Mine came loose when locked and key was removed but never became detached but coming anything isn't good. Might be a case then that bod as LR didn't know what they were talking about but did continue using standard neck just checked it was fully engaged all the time. I know in evo's case LR claimed bar wasn't inserted fully even though key was removed. The stop strap did its job and stopped the trailer before it did any damage.
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 ![]() ![]() ![]() |
I tow a horse box every week and the towball does loosen over a journey, it also does not seem to lock solid at all like it used too so I am assuming it has worn over time. Towing a 6 berth Elddis in August caused it to loosen a worrying amount after a 200 mile journey. 2014 Nara Bronze SDV6
