![]() | Home > Technical > Tow Bar Won't Detach! |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
As per title, I can't get the flamin thing to come off! Handle pulls out and turns but not releasing the tow bar. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
Check if the locking pin from spare wheel side is sliding to unlock-lock positions If yes, it means that tow bar is rusted to its slot.
WD40 and lump hammer it is, I'll let you know how I get on! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Lump hammer won! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
What was the problem for you? |
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 ![]() ![]() ![]() |
I had a similar problem with mine, the green handle bit snapped off, we got it off eventually now I have no green handle on the tow bar (i have a new one to fit), we took out all the inners, now the actual locking catch is stuck in - Any ideas??? About to get into a sport |
will re-priming the trigger pin work? RRS gone
Is the trigger pin the little silver button on the top About to get into a sport |
it's the pin that's labelled locking pin in the picture above.
Hi AWD Man - on my tow hitch the locking pin is stuck inside the hitch
hmm that looks pretty unhappy!
I had the same problem before. I drilled the hole 6mm opposite to stuck pin hole and used hummer to push pin out. When pin was free the hole was welded, then grind till it looks like was before. Sanded the whole tow bar, painted matte black, new green lock and it lookes like new |
gruodiz
see pic, when you drill the hole you can push pin out so it's 180deg to the pin working direction
