Home > Technical > Tow Bar Won't Detach!
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
As per title, I can't get the flamin thing to come off! Handle pulls out and turns but not releasing the tow bar. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #395719 Sat Sep 21 2013 10:15pm
muddywheels
Milk Float Man
Try tapping tow bar with a hammer to loosen it and/or maybe some wd40 in the socket - they can stick if left on - I always remove mine now after leaving overnight once and having exactly this problem Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #395723 Sat Sep 21 2013 10:35pm
gruodiz
Lithuania
Check if the locking pin from spare wheel side is sliding to unlock-lock positions If yes, it means that tow bar is rusted to its slot.
Actually there're 3 main reasons not to detach the tow bar.
1. key doesn't get in or doesn't turn unlock but locking pin from spare wheel side slides half way to release position. no problem with locking pin. patience, wd40, compressed air gun with 10bar, needle and you're done.
2. no problem with key but locking pin from spare wheel side doesn't slide - rusted pin to the tow bar where it sits. wd40 for couple days sprayed from spare wheel side each day for 3-4 times may solve it but this is the biggest problem I ever had with tow bar. car was on lift, spare wheel removed, lock unlocked and twisted as required and other person was hammering locking pin from spare wheel side.
3. no problem with key lock, no problem with sliding locking pin but tow bar rusted it self to its slot, couple hit with bigger hammer and it's solved
Post #395783 Sun Sep 22 2013 3:50pm
RossM
WD40 and lump hammer it is, I'll let you know how I get on! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #395789 Sun Sep 22 2013 4:24pm
RossM
Lump hammer won! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #395822 Sun Sep 22 2013 9:23pm
gruodiz
Lithuania
What was the problem for you?
Post #395824 Sun Sep 22 2013 9:51pm
Simon58
England 2008 Range Rover Sport TDV6 HSE Galway Green
I had a similar problem with mine, the green handle bit snapped off, we got it off eventually now I have no green handle on the tow bar (i have a new one to fit), we took out all the inners, now the actual locking catch is stuck in - Any ideas??? About to get into a sport
Post #395916 Mon Sep 23 2013 7:21pm
will re-priming the trigger pin work? RRS gone
Post #395951 Tue Sep 24 2013 8:28am
Simon58
Is the trigger pin the little silver button on the top About to get into a sport
Post #395957 Tue Sep 24 2013 9:48am
it's the pin that's labelled locking pin in the picture above.
Sometimes if it's in "lock" the whole mechanism is in the wrong mode.
Worth a shot, but re-reading your post I'm not sure that's your problem.. Is it the locking barrel that will not pull out? RRS gone
Post #395963 Tue Sep 24 2013 10:02am
Simon58
Hi AWD Man - on my tow hitch the locking pin is stuck inside the hitch
Post #396019 Tue Sep 24 2013 4:04pm
hmm that looks pretty unhappy!
I'd have expected the locking pin to be out, due to the fact there is no locking barrel in place to hold it in!
Sorry, got me stumped on that one. RRS gone
Post #396022 Tue Sep 24 2013 4:37pm
gruodiz
Lithuania
I had the same problem before. I drilled the hole 6mm opposite to stuck pin hole and used hummer to push pin out. When pin was free the hole was welded, then grind till it looks like was before. Sanded the whole tow bar, painted matte black, new green lock and it lookes like new Very Happy
EDIT: Used hummer with other ~5-6 mm pin to push locking pin out
Post #396033 Tue Sep 24 2013 6:02pm
Simon58
gruodiz
I am a little confused at what bit I drill, I like the idea just not sure what bit to drill! About to get into a sport
Post #396101 Wed Sep 25 2013 9:19am
gruodiz
Lithuania
see pic, when you drill the hole you can push pin out so it's 180deg to the pin working direction
Post #396103 Wed Sep 25 2013 9:41am
