Home > Technical > Upper Tailgate Unlocking on Start
Bobby
It could be due to switch failure/jammed or switch signal circuit short circuit to ground. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #395583 Fri Sep 20 2013 2:12pm
garrycol
Australia
Thanks Bobby - however the problem persists even when the switch is disconnected so I am a bit of a loss what else the issue could be.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #395640 Sat Sep 21 2013 3:46am
Bobby
The short could be in the unlock wiring circuit itself...meaning the short is unlocking the tailgate glass.
It would be good if you could check the tailgate unlock circuit. Malaysia Boleh!
Post #395680 Sat Sep 21 2013 11:42am
garrycol
Australia
Yes - I agree but not sure how I would do that - maybe it is time to have an expert look at it but there are none local. There is a dealer but - hmmm - no thanks. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #395681 Sat Sep 21 2013 11:57am
Paddi
Have you a copy of the workshop manual? If not then there is an online version of the Disco 3 one here: http://landrover.workshop-manuals.com/lr3/index.php?id=2521
Might give you some clues. First place I would check for short circuits is where the wiring passes through the flexible grommet things going from the body to the tailgate. You can access by removing the spoiler. 2008 MY Java Black TDV8 HSE
Post #395688 Sat Sep 21 2013 1:48pm
garrycol
Australia
I went out with the multimeter to start tracking the cabling etc but the problem has now gone - there are issues whatsoever. Having been driving around a bit and no issues - all very confusing. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #395838 Mon Sep 23 2013 7:26am
baxc
keep an eye on your battery this was the start of my problems after a while the tailgate stays shut but the problem drains your battery
Post #395860 Mon Sep 23 2013 12:19pm
garrycol
Australia
Yes will do - thanks. Seems Ok though.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #395863 Mon Sep 23 2013 12:34pm
