![]() | Home > Maintenance & Modifications > Range Rover Sport Angel Eye DRL's |
You could teach awd a lesson or two on how to fit angel eyes correctly first time. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
I assume that you have them set to come on with the ignition. If so where did you take your switched 12v from.
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
I had to route it from the engine firewall straight into the fuse box in the passenger side. A big and long inconvenience because to find a 12v fuse which switches on with the engine on the engine bay fuse box was impossible. I couldn't find a single fuse there.
BioBMS Member Since: 14 May 2013 Location: Oulton. Staffs Posts: 16 ![]() ![]() ![]() |
Looks super |
Thanks for the information - I haven't seen the kits advertised but will continue to search on a regular basis. Thanks Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Here you go Garry,
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
There is an ignition switched fuse in the engine bay fuse box |
Which one? ![]() |
http://www.ebay.co.uk/itm/DRL-Daytime-Runn...3f14a892ff |
Thanks for that Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
