![]() | Home > Technical > Front left wheel skidding/braking |
| RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80
When taking right hand bends slightly faster than normal (not a lot though) I get the feeling that that the front left wheel brake is being applied or the wheel is locking up. Its progressively getting worse. Initially it only did it when aggresively cornering but now its happening under less and less force. Has anyone experienced this or know what it could be? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Are you sure its not the ABS kicking in because your going to fast, check your tyres, does it do on full lock, just on a right hand bend.?
as above, but also get the wheel alignment checked or the steering wheel recalibrated as it could be either of those as well. |
Its not on full lock nor actually going that fast (except when the misses is driving |
Cleaned all the brakes out and cleaned the ABS sensor which seemed to solve the problem but my wife has informed me that's its still doing it!! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
| Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289
ARB Bushes next then |
Just ordered them off your site!!! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
I know, was just being a little cheeky |
have you had the steering calibrated and the wheel alignment done? Thats the most usual cause (other then low tyre pressure) |
How does the steering get calibrated? Or is it part of the wheel alignment? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
I thought this problem had gone away following fitment of new brake pads when it went in for MOT but it seems not as it's now come back. It's quite unnerving when it happens! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
| All times are GMT |
