Home > Technical > Front left wheel skidding/braking
RossM
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
When taking right hand bends slightly faster than normal (not a lot though) I get the feeling that that the front left wheel brake is being applied or the wheel is locking up. Its progressively getting worse. Initially it only did it when aggresively cornering but now its happening under less and less force. Has anyone experienced this or know what it could be? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #385922 Wed Jun 19 2013 7:13am
flack
Are you sure its not the ABS kicking in because your going to fast, check your tyres, does it do on full lock, just on a right hand bend.?
Flack Thumbs Up
Post #385925 Wed Jun 19 2013 7:24am
Bodsy
Site Sponsor
as above, but also get the wheel alignment checked or the steering wheel recalibrated as it could be either of those as well. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #385940 Wed Jun 19 2013 8:58am
Peanut
I have had this - turned out to be crud on the disc causing binding and telling the Stability control to switch in.
Humbly suggest that you check easy things like wheel nuts, tyre pressures.
Then Bodsy's recommendations if you don't find anything!
Post #385944 Wed Jun 19 2013 9:21am
RossM
Its not on full lock nor actually going that fast (except when the misses is driving Laughing ). i'll check tyre pressures tonight and check brakes. Tracking is pulling a little to the left so will get that done too.
Thanks Guys. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #385946 Wed Jun 19 2013 9:35am
RossM
Cleaned all the brakes out and cleaned the ABS sensor which seemed to solve the problem but my wife has informed me that's its still doing it!! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #390933 Mon Aug 05 2013 10:01am
Advanced Factors
Site Sponsor
ARB Bushes next then Whistle Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #390939 Mon Aug 05 2013 10:38am
RossM
Just ordered them off your site!!! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #390940 Mon Aug 05 2013 10:52am
Advanced Factors
Site Sponsor
I know, was just being a little cheeky Thumbs Up Paul Redding
+44 (0)23 8052 2776
Post #390941 Mon Aug 05 2013 10:58am
Bodsy
Site Sponsor
have you had the steering calibrated and the wheel alignment done? Thats the most usual cause (other then low tyre pressure) Thumbs Up Bodsys Brake Bible
See it HERE
Post #390987 Mon Aug 05 2013 4:42pm
RossM
How does the steering get calibrated? Or is it part of the wheel alignment? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #391005 Mon Aug 05 2013 8:00pm
RossM
I thought this problem had gone away following fitment of new brake pads when it went in for MOT but it seems not as it's now come back. It's quite unnerving when it happens! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers
Post #399055 Sat Oct 19 2013 6:24pm
