Home > Technical > red suspension warning light
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
the red suspension warning light keeps coming on and soon as i clear it it will start flashing the come on solid again, fault code c1119 hydraulic pressure and u0416 invalid data received from vehicle dynamics control module and u0434 invalid data recieved from active roll control module active stabilization system, any ideas please
Post #390291 Sun Jul 28 2013 10:04pm
DaveRRS
I assume its the same as mine, needed a new pump/compressor for the hydraulic suspension.
The part is about £450 + 1.6 hours labour, at least that's what I paid 2 weeks ago. 2007 TDV6 HSE Stornoway Grey
2007 Kawasaki Ninja ZX-6R
Post #390302 Sun Jul 28 2013 10:22pm
cossiedave
it started about a year ago but has been coming on more often recantlly, where is the pump situated dave and thanks for the reply Thumbs Up
Post #390305 Sun Jul 28 2013 10:25pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
rear near side. just in front of the rear wheel.Its in a black cover box. Turn on your car and you ll hear it.
Post #390324 Mon Jul 29 2013 9:06am
cossiedave
Thanks mate just found it so will investigate. Looking at the rear air bags and they are both flat but the car goes up and down instant. Should the bags be solid
Post #390340 Mon Jul 29 2013 2:50pm
SCdavies
if your car isn't sinking to it's bump stops and goes up and down ok it sounds ok. If your getting the red warnings you need to get it sorted sooner rather than later. I've just changed my pump after Amber warnings.
Post #390353 Mon Jul 29 2013 6:26pm
cossiedave
i put some lowering link rods on it about a year ago and was thinking it maybe them as when i put it in acces mode it come straight back up again so maybe when it goes in motorway way mode it might put the light on, i have removed them today to see if it was any better
Post #390370 Mon Jul 29 2013 8:05pm
flack
If you do change the pump you need to put a new relay in it and also the new software for the AMK compressor, but some RRS I have tried to update spit there dummy's out and don't like the new software.
Flack Thumbs Up
Post #390377 Mon Jul 29 2013 8:57pm
cossiedave
Flack Thumbs Up
sounds complacated mate
Post #390379 Mon Jul 29 2013 9:06pm
SCdavies
i did nt need the new software and she works fine. out of interest though what is different in the software? thanks
Post #390423 Tue Jul 30 2013 10:45am
Mine's going in tomorrow (amber light) RRS gone
Post #390431 Tue Jul 30 2013 11:02am
flack
The new software runs at a lower pressure so does not put as much strain on the pump
Flack Thumbs Up
Post #390448 Tue Jul 30 2013 2:52pm
cossiedave
Flack what price is a software update
Post #390460 Tue Jul 30 2013 5:19pm
gruodiz
Lithuania
Flack, it's ARC anti roll control stabilizers fluid pump.
Not air compressor. Thumbs Up
Post #479658 Thu Nov 12 2015 11:18pm
