![]() | Home > Technical > red suspension warning light |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
the red suspension warning light keeps coming on and soon as i clear it it will start flashing the come on solid again, fault code c1119 hydraulic pressure and u0416 invalid data received from vehicle dynamics control module and u0434 invalid data recieved from active roll control module active stabilization system, any ideas please |
DaveRRS Member Since: 04 May 2012 Location: Reading, Berkshire Posts: 178 ![]() ![]() ![]() |
I assume its the same as mine, needed a new pump/compressor for the hydraulic suspension.
it started about a year ago but has been coming on more often recantlly, where is the pump situated dave and thanks for the reply |
Thanks mate just found it so will investigate. Looking at the rear air bags and they are both flat but the car goes up and down instant. Should the bags be solid |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
if your car isn't sinking to it's bump stops and goes up and down ok it sounds ok. If your getting the red warnings you need to get it sorted sooner rather than later. I've just changed my pump after Amber warnings. |
i put some lowering link rods on it about a year ago and was thinking it maybe them as when i put it in acces mode it come straight back up again so maybe when it goes in motorway way mode it might put the light on, i have removed them today to see if it was any better |
If you do change the pump you need to put a new relay in it and also the new software for the AMK compressor, but some RRS I have tried to update spit there dummy's out and don't like the new software.
sounds complacated mate |
i did nt need the new software and she works fine. out of interest though what is different in the software? thanks |
Mine's going in tomorrow (amber light) RRS gone
The new software runs at a lower pressure so does not put as much strain on the pump
Flack what price is a software update |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
Flack, it's ARC anti roll control stabilizers fluid pump.
