Home > Faults & Fixes > Rattle/Knocking at low speeds
Nevski
England 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi Martin and all members, I own a 2010 Range Rover Sport3.0 TDV6 HSE(face lift)model, 4th Land Rover I have owned last one being a Disco 3 TDV6, However an annoying rattle/knocking has started which appears to be coming from the front suspension when the vehicle is driven at slow speeds over small potholes or rough areas of road surface. The vehicle has never been off road and has less than 30,000 miles.
Has anyone experienced similar or knows what it could be?
Confused Nev.
Post #389960 Thu Jul 25 2013 7:19pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Lower arms anti roll bar bushes or droplinks
Post #389963 Thu Jul 25 2013 7:23pm
Nevski
Cheers Neil, Main dealer looked at it in march, first said there was nothing wrong but that some RRSports could be prone to annoying rattles that you had to live with Surprised They did however take a look and low and behold it all went quiet for 3 months. But it has started up again Mad At least now I have an idea when I return to them.
Cheers Nev
Post #389964 Thu Jul 25 2013 7:38pm
Advanced Factors
Site Sponsor
They may of just shimmed out your ARB bushes, same issue the D3's have.
Might explain why it's come back. ARB links are also a common sale for us. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #389965 Thu Jul 25 2013 7:49pm
Nevski
Cheers Steve,
If shimming out the ARB bushes is what sounds like a quick easy fix, what sort of cost is a replacement? and should this part ware out within 30,000 miles or is this a known land rover fault?
You say this is a common fault with D3,s, same running gear I presume?
Nev
Post #389969 Thu Jul 25 2013 8:56pm
Advanced Factors
Site Sponsor
The D3 setup is very similar but not quite the same.
RRS prices here - http://www.advancedfactors.co.uk/steering-...t-22-c.asp
Any of these items could be your noise and to be fair we sell this sort of set for every type of car, Corsa, Focus or indeed a Rangie. Paul Redding
+44 (0)23 8052 2776
Post #389980 Thu Jul 25 2013 9:42pm
Bobby
If you have Dynamic Response...
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #389982 Thu Jul 25 2013 10:17pm
Nevski
Hi Bobby,
Thanks for the info, I've always assumed the vehicle had dynamic Response however the noise coming from under the front is more of a knock than a squeak or creak, also the warning light has not illuminated.
I was in Kuala Lumpur last November lovely place enjoyed the visit.
Cheers Nev.
Post #390008 Fri Jul 26 2013 9:55am
A knock would suggest the ARB bushes initially. They are effectively wear-and-tear items. 2012 SDV6 - it's missing a couple of cylinders
Post #390016 Fri Jul 26 2013 10:47am
muddywheels
Milk Float Man
I had this for 3 years and dealer said it was a "characteristic" and would not fix Evil or Very Mad
Glad to say new black edition does not have this characteristic yet Cool
Good luck Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #390019 Fri Jul 26 2013 10:51am
I had ARB bushes changed under warranty by my local LR dealer. That was under the Approved Extended warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #390020 Fri Jul 26 2013 11:00am
Bobby
You could refer your dealer to LTB00241v7, Front Suspension Knock Improvement.
This TSB concerns RRS vehicles with Dynamic Response only, Model Year: 2007-2011
VIN: 7A983118-BA716646
This addresses "an audible knock heard from inside the vehicle when driving along a poorly maintained uneven road surface, e.g. with one wheel driving over a drain cover, with the vehicle driven straight ahead".
The remedy is to install the Mass Absorber Kit and replace the existing Dynamic Response Bushes and Clamps.
Cool Malaysia Boleh!
Post #390021 Fri Jul 26 2013 11:13am
