Home > General > Tailgate stuck !!!!
chrisebabes
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Tailgate stuck !!!!
My tailgate has decided not to open the glass top bit, if you push the button the whole thing opens but not just the glass bit.
It worked ok yesterday any ideas !!! Sad Sad
Post #388286 Wed Jul 10 2013 8:07am
simple1
Button? The big round one in bootlid? To open glass, switch is under handle between the number plate lights, the button only opens the tailgate. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #388288 Wed Jul 10 2013 8:29am
muddywheels
Milk Float Man
Chris - do you mean remote button Confused
The button on remote is programmable to do glass or whole boot Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #388289 Wed Jul 10 2013 8:35am
simple1
Shocked forgot about that button Whistle mine was always programmed to open entire boot lid Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #388300 Wed Jul 10 2013 10:10am
chrisebabes
Tailgate
Hi guys. No not the button it's the other one for the glass bit. Button works fine to open the whole thing.
Post #388303 Wed Jul 10 2013 11:40am
Paddi
Prime suspect is the switch - known to be a weakness. You press the rubber cover which operates a lever which in turn operates a tiny microswitch. The whole switch assembly is a simple DIY job to replace; it can be carefully levered out without doing any other dismantling but there is less chance of doing damage if you first remove the plastic trim piece below the rear window glass and gain better access.
PS: link here to a video showing how easy it is to remove the trim piece:  2008 MY Java Black TDV8 HSE
Post #388304 Wed Jul 10 2013 11:59am
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
Hi, how do you programme the remote button to open the glass as apposed to the whole boot?
cheers 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #388405 Thu Jul 11 2013 12:37pm
muddywheels
Milk Float Man
According to handbook for 2006 Bow down
Quote:
Programme by keeping the Land Rover button
pressed and also pressing the main tailglass
release button situated under the rear number
plate plinth.
A short press of the button will now cause the
vehicle’s tailglass to release.
Post #388407 Thu Jul 11 2013 12:50pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: Tailgate stuck !!!!
Hi Chris yes it is the tailgate switch which is at fault. Remove switch from between number plate lights. Remove rubber cover and you will see the problem, the alloy hinge piece will be corroded. When you push the rubber button, it pushes the hinge up onto the micro switch. But because it is corroded it does not move. Scape it off and give it some WD40. I did this 18 months ago,still working fine. A new switch on ebay is about £25 itisme
Post #388802 Sun Jul 14 2013 8:26am
chrisebabes
Now Sorted
Got a new switch took all of 2 mins to fit now I'm a happy bunny again, thanks for everyones help
Post #388846 Sun Jul 14 2013 9:34pm
Paddi
Thumbs Up another victory for the forum. Always good to hear the outcome. 2008 MY Java Black TDV8 HSE
Post #388892 Mon Jul 15 2013 11:05am
Preston-rr
All sorted with this thanks to flack who had the RRS in last week for a service, cambelt changes. Really nice guy, very knowledgable, ran me back to work and sorted my tailgate switch for the upper section which wasn't working. Gives me real piece of mind knowing a local guy that I can trust and has the knowledge of these.
Recommended!
Thanks flack. Il be back for those software updates and rear lights to be fitted soon.
Cheers 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #389992 Thu Jul 25 2013 11:23pm
