![]() | Home > General > Swaying problem |
| Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657
Your suspensions fooked 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
| dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23
Hi
I'd be surprised if anyone can identify your problem over the net in order for you to order parts.
Maybe someone will have had the same problem and knows the oats needed D Ledingham |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
I will hazard a guess, rear wishbone bushes. If your doing them, you need to replace the lot, 4 each side. And replace all the bolts and captive nuts as will bet you will have to cut at least two. |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
You've probably checked tyre pressures ! |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Have a look underneath? Anti-roll bar drop link(s) come adrift/broken or bushes cream crackered? 2008 MY Java Black TDV8 HSE
Just had my Rrs in garage today and no faults were found with any of the bushes atall tyre pressure was at 40 gArage recommended put tyre pressure to 45 ???
With 20" wheels I ran 42 rear and 36 front. Had 100% even tyre wear. Pumped rears up to 46 when towing. Can say the tyre pressures being a little off would cause rear to sway at speed. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
4 wheel alignment then |
Is this a new problem or has it just developed?
Hi there my tyre sizes are
The sway just ain't at speed it will do it in town at 30 mph only when I hit a bump but not every bump will do it , it's only when one wheel goes in a pot hole or something like that
Sway= movement in back end. Simples. Tyres will not affect the car at low speed even with 22 wheels. Might make the ride a bit more uncomfortable. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| All times are GMT |
