Home > General > Swaying problem
Might be a sensor issue - the bump might be making the car think it's wayward so it uses the brakes to straighten it up. But as it's not out of line the system actually makes it sway. Be worth checking the ride height sensors, the wheel speed sensors (ABS) and perhaps the steering angle sensor. Maybe the bump upsets the yaw rate sensor.
This is assuming that the suspension itself is all correct (bushes and alignment). 2012 SDV6 - it's missing a couple of cylinders
Post #387616 Tue Jul 02 2013 7:16pm
dal1557
Hi
Wouldn't the sensors being faulty show up on a diagnostic check? I've had a diagnostic test and a upgrade on my suspension to Mach the new air compressor D Ledingham
Post #387618 Tue Jul 02 2013 7:23pm
ShooterNeil
Sounds the same as mine skittish back end and the odd clunk coming off islands
I have lower arms /ARB bushes /drop links and inner /outer tie rods to change on the front as the steering wobbles at 50-60 mph first
Ho and a drivers door latch to swap over as it locks in stages lol
Post #387837 Thu Jul 04 2013 10:45pm
Paszko
2005 Range Rover Sport TDV6 HSE Siberian Silver
Dal1557 did you manage to get to the bottom of this?
I'm having the same when I hit a small bump, this can be on the motorway, speedbump or very slightest bump at low speeds. My tyres are to correct pressure and 4 wheel alignment has been done.
I'm thinking bushes on back. Any advise would be appreciated.
Lee
Post #398737 Thu Oct 17 2013 6:44pm
dal1557
ive had all my bushes changed front and back runs perfect now
wasnt cheap tho
worth every penny tho D Ledingham
Post #398785 Thu Oct 17 2013 10:21pm
Paszko
Do u know if it was the top or bottom ones, or both you had changed.
Post #398790 Thu Oct 17 2013 10:56pm
Bodsy
Site Sponsor
The usual failures are the front lower wishbones and the rear upper wishbones. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #398949 Fri Oct 18 2013 7:46pm
Paszko
Bodsey thanks for that, my mechanic suggested that it could be the rear upper ones. had the lower front ones done about 6 month ago, so looks like im ordering the rear ones also.
Post #399037 Sat Oct 19 2013 3:23pm
