Home > General > I need Help for my first Land Rover, a 2.7 tdv6s.
Page 1 of 3 123>
jagspete
2007 Range Rover Sport TDV6 S Buckingham Blue
Hello all, I have been passionated at Jagaur for 14 years with 10 jags, I am now planing to buy a 2007 Land Rover RRS TDV6S. but i need some advices please, I am wandering how is the engine, power? what should i expect like repairs at 55000km?
I can't tell if there is a gps? navigation system?
Thank you. tdv6s 2.7 2007
xkr 5 2010
Post #385389 Thu Jun 13 2013 8:45pm
tanloverluke
no navigation system in this one matey Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #385392 Thu Jun 13 2013 9:16pm
simple1
S is the base model that isn't available in the UK. Only in Disco. But won't have sat nav, unlikely to have heated seats or any other toys.
55000 km is @ 38000 miles so it depends on age. TDV6 needs timing belts at 115000 miles or ten years but should be done before that. Expect to do heater plugs about the same time. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #385394 Thu Jun 13 2013 9:42pm
jagspete
Tanloverluke and Simple1, Thank you!! any idea of the average price to change the timing belt and heater plugs? tdv6s 2.7 2007
xkr 5 2010
Post #385399 Thu Jun 13 2013 9:55pm
flack
Timing belts should be done at 7 years not 10...
Flack Thumbs Up
Post #385400 Thu Jun 13 2013 9:59pm
simple1
Depends where you take it and if the plugs come out as known to be a problem.
TDV6 requires two belts, front is reasonably easy, the rear is a pain. I think dealers charge £1000 to supply and fit belts and tensioners. Rolling Eyes
Heater plugs can cost £60 or Several thousand. If plugs don't come out, body off and remove heads, lots of work. Several independents can remove seized plugs for £60 each in the car. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #385402 Thu Jun 13 2013 10:03pm
jagspete
About the oil change is it due like for the jags every year or is it more time? tdv6s 2.7 2007
xkr 5 2010
Post #385565 Sat Jun 15 2013 11:34pm
simple1
15000 miles or every year. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #385571 Sun Jun 16 2013 8:00am
jagspete
Thank you! Thumbs Up tdv6s 2.7 2007
xkr 5 2010
Post #385573 Sun Jun 16 2013 8:33am
jagspete
Hello guys,
so I went to try the range today and i think I will be buying it tomorrow or the day after.
One question,
I think the wheel are 18'', i found the suspension not so firm even in low position, what could improves this, new wheels bigger, or new shocks, the car is only 50000 km, but from 2007? and also lot of noise with the dashboard.
any ideas, I like the color a lot navy blue.
here is the ad: it is indeed blue, the dealer who have it, listed it as black...by chance i found the owner so i got it for cheaper.
http://www.autoscout24.es/details.aspx?smi...=232205347
thanks tdv6s 2.7 2007
xkr 5 2010
Post #385796 Mon Jun 17 2013 9:37pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Mine is an S and came with 17" wheels which I changed to 19" and it totally tranformed the ride and drive Thumbs Up
Post #385804 Mon Jun 17 2013 11:36pm
jagspete
Thumbs Up mine must be 17'' too i am not familiar enough to say, Thanks! this is what I will probably do too, too bad i got new tires on these 17''. it is Michelin new tires but i do not like michelin. tdv6s 2.7 2007
xkr 5 2010
Post #385805 Tue Jun 18 2013 12:13am
Alan61
2013 Range Rover Sport SDV6 HSE Santorini Black
The picture in the advert link shows the wheels to be 18" Thumbs Up
Good luck!
Post #385807 Tue Jun 18 2013 6:49am
jagspete
Good luck!
Thanks Alan61! tdv6s 2.7 2007
xkr 5 2010
Post #385808 Tue Jun 18 2013 7:25am
jagspete
Hi all,
I wanted to ask, what is the firmer suspension settings? hiway and lower settings?
thank you. tdv6s 2.7 2007
xkr 5 2010
Post #385902 Tue Jun 18 2013 8:40pm
Page 1 of 3 123>
