![]() | Home > General > I need Help for my first Land Rover, a 2.7 tdv6s. |
| jagspete Member Since: 13 Jun 2013 Location: Valencia Posts: 165
Thanks a lot. I contacted Pete at Bellautos but no response yet. tdv6s 2.7 2007
I have a question, regarding the suspension settings, there is 3 different one, can we use the lowest one for driving?
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
You can not drive in Access Mode (the lowest ride height). Above a certain speed the vehicle will automatically raise itself to Normal Mode (the middle ride height). The last setting, Off Road Mode, is also speed limited and the vehicle will lower itself back to Normal Mode at a set speed.
RRSTDV8 , yes I know what you meant I set up a lowering module on a xj already, maybe i will not do anything then, even unsure to remaps it,
One more question,
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
You can set a delay on the dash for "coming home lights". So if set for 30 secs, when you turn car off, the. Lights stay on for set period. Turning light switch from auto or headlights to sidelights over rides this. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
jagspete
yes thank you Simple1,i find out today, its exactly what's happening. Thank you SRE! tdv6s 2.7 2007 xkr 5 2010 Last edited by jagspete on Fri Jun 21 2013 11:14am. Edited 1 time in total |
I am not going to do anything, no wheel change, no module to lower it, and no remap finally, or later. Do you think a remap could break the turbo prematurely. one liter of coolant was missing and the battery need 1.5 liter of distilled water...i am this afternoon at land rover as he is a friend of mine. tdv6s 2.7 2007 xkr 5 2010 |
I am not going to do anything, no wheel change, no module to lower it, and no remap finally, or later. Do you think a remap could break the turbo prematurely ????
PS.
SRE, thanks a lot, I asked the dealership they said if your engine will last 8 years with a remap it will last 4 years. I know it s_cks like response but i am broke like a pair fo shoes now... I am tented to do it but i have no warranty and a xkr 5 liter to maintain too. Thanks a lot guys, re all these modification, it be cool to see some photos... tdv6s 2.7 2007 xkr 5 2010 |
I did not get anything out of your euro 3...thing? how can i find out¿ sorry if i am being such a... tdv6s 2.7 2007 xkr 5 2010 |
But what engine do you have, mine is a 2.7? does all S serie are 2.7? as i am concerned with bigger wheel it may feel slower. tdv6s 2.7 2007 xkr 5 2010 |
| All times are GMT |
