![]() | Home > General > Advice on RRS TDV8 |
As one of the few long term owners, my advice would be that it doesn't matter how carefully you buy, things can and will go wrong. I was one of the first to take delivery and owned mine from new, the list of failures would require pages on here and the current situation is well documented in another thread.
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
And don't forget the thick end of £500 to tax them 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
customcarsuk Member Since: 15 Mar 2013 Location: west midlands Posts: 76 ![]() ![]() |
Buy one with a Land Rover Approved Warranty. |
Bigmark Member Since: 12 May 2013 Location: kent Posts: 15 ![]() ![]() |
Thanks for the replys, so in the long run are they like any other car for problems or would you say they are more prone to things going wrong. when you read some of the post's on here it can be off putting but its the same with most car sites. you read the parkers review's and they dont tell you all the things im finding out on here. i.e what life span do the turbo's have. im starting to think do i buy one a bit cheaper and and then get things like the brake pipes checked and repllaced etc. what sort of price do they charge for the job of doing brake pipes. the reason im asking these questions ive got some money coming in aug and i want to treat myself i was looking at a s class merc but im finding my knees are playing me up getting into cars that sit lower and when i sat in a RRS i just went in with no bending down so it was great, and its going to be a car that i hope to own for a long time. as for service do they have timeing chains or belts. are you better of getting all your work dome by a RR dealer. |
Chrale Member Since: 15 Feb 2013 Location: North East Posts: 77 ![]() ![]() ![]() |
Having owned many different makes and models of cars, they ALL come with their faults. I'm fairly new to RRS ownership and have already seen an £1800 bill. However, i always factor in the costs that come with running each individual car i have owned, based on reading forums, how much car was when new, maintenance costs from dealers and independants, as you are doing here.
Thanks Charlie, are both TDV6 and TDV8 prone to the same faults? and i see someone say that in 2009 it doesnt have the same problems as the earlyer one's because of RR sorting out some of the problems, is this true i thought it was still the same RR but with different extras |
TDV6 has its own problems, so does V8. Post 2009 v6 had tensioner/oil pump addressed and software issues resolved.
if im looking at a 2008-2009 model does a Land Rover Warranty still cover it for most of the problems or do they start saying its down to wear and tear, is the warranty only anygood on new cars? |
http://www.usedvehicles.landrover.co.uk/approved-warranty
LR warrentee will cover most parts unless they can prove it is wear and tear but you will have a record of commin failures to vive fodder to argue. But be aware, from the small print, that each claim has a value limit of £3000. You can make multiple claims up to value of car. So for £1180 quid you don't get enough to cover major failures, my bill is in excess of £12800 and climbing, but I have to say that LR will look more favourably at making a contribution if you have their warrentee than if you have an alternative or none at all. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Coolj Member Since: 27 Aug 2007 Location: London Posts: 85 ![]() ![]() ![]() |
I can say that I am one of the fortunate few that hasn't had any major issues with my TDV8. I've had it for 5 years from new and my only layout has been the yearly servicing, changing tires and minor wear and tear. |
By the law of averages, there has to be plenty out there that has had no problems. As so often the case, the ones without problems are not heard on forums. No news travels as fast as bad news. |
ok thanks guys |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 ![]() ![]() ![]() |
Turbo's are usually very reliable, a good many last the life of the vehicle especially if simple start up and shut down instructions are followed, the main reason for turbo failure is abuse or ignorance of following these instructions by the driver. No offence intended, just advice to a prospective owner and other owners ![]() |
