Home > Technical > Removing torx wheel disc retaining screw
garyc
2005 Range Rover Sport Supercharged HSE Java Black
Trying to change the front disc on my RRS S/C and not matter what I have tried can't get the torx retaining screw out.
Tried hammering, impact driver, and heat but nothing shifts it, even twisted the torx bit.
Does anyone have any other ideas?
Was going to weld a nut onto the screw and then should be able to get it out.
Is there anything to be careful about when mig welding. Is dosconnecting the battery enough to ensure no damage is done to the car?
Thanks
Post #382562 Thu May 09 2013 7:50am
Disco_Mikey
I find hammering the disc around the screw helps to loosen it, or hammer the torx bit into the screw. Same thing, just helps shock it loose Thumbs Up
Post #382582 Thu May 09 2013 10:11am
garyc
Tried every way to loosen it but it won't go. Hammered it but it won't budge.
If I go the route of welding a nut onto the screw what precautions would I have to take to ensure there is no damage to any of the systems of the car. Is disconnecting both battery terminals and leaving for about ten minutes enough?
Thanks
Post #382584 Thu May 09 2013 10:14am
Disco_Mikey
Yes, disconnect the battery and leave for a bit Thumbs Up
Post #382585 Thu May 09 2013 10:16am
