![]() | Home > Technical > Removing torx wheel disc retaining screw |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4528 ![]() ![]() ![]() |
I find hammering the disc around the screw helps to loosen it, or hammer the torx bit into the screw. Same thing, just helps shock it loose |
garyc Member Since: 23 Feb 2012 Location: UK Posts: 33 ![]() ![]() |
Tried every way to loosen it but it won't go. Hammered it but it won't budge.
Yes, disconnect the battery and leave for a bit |
