Home > General > clear smoke coming from right front wheel? oil?
ajp166
Guys car was running for a while and I notice clear smoke coming from above wheel on drivers side... I looked under bonet and pulled the oil dipstick out and there was so steam (clear) coming from it then I opened the oil cap and some steam coming from there also... its constant also... is this normal for a TDV8? 87k miles on clock..
Post #381017 Sat Apr 20 2013 3:47pm
Disco_Mikey
Is it leaking anything? Have seen the injector leak off pipes fall out, and the diesel hits the hot exhaust underneath, causing smoke...
Post #381018 Sat Apr 20 2013 3:53pm
ajp166
From the wheel it's very hard to see it.. Is it normal that if the car running and you pull the dipstick out for there to be smoke coming from there ? Should the oil be that hot?
Post #381019 Sat Apr 20 2013 4:31pm
mse
It can be normal, but it can be an indicator of a head gasket/piston failure, but to be honest it's difficult to tell from what you describe.
Any other issues, any creaming at the oil filler? Mike
2014 Facelift Discovery
Post #381035 Sat Apr 20 2013 6:29pm
ajp166
Just checked the oil level and its just above the min amount.. could that be the reason? the dipstick was strange as one side says its above min but the side with the dots show it just above min...
checked the oil cap and no white stuff etc...
Post #381049 Sat Apr 20 2013 8:35pm
mse
When did you last fill it. Fill it up and make sure it's not using oil
Did the oil look clean? Was the coolant level ok?
Is the smoke puffing out? Mike
Post #381050 Sat Apr 20 2013 8:40pm
ajp166
Thanks.
Yes coolant is fine... oil looked fine.. I didnt add oil to it as land rover serviced it 10k miles ago...i assumed the dash would tell you when to add?
Whats the best way to get a true reading? I dont want to over add oil...
Post #381051 Sat Apr 20 2013 8:45pm
mse
If you have a dip stick then that's what you go off.
Is it puffing out or not. As everything sounds clean it probably isn't the head, it could be a worn piston...depends Mike
Post #381052 Sat Apr 20 2013 8:48pm
ajp166
Do I check when engine cold or warm (after a run)... I checked now when cold as thats what i've always done..
Post #381053 Sat Apr 20 2013 8:50pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Engine should be warm when checking oil level. 10,000 miles without checking Question Monthly at least.
Post #381054 Sat Apr 20 2013 9:13pm
mse
Check your oil when cold
Change it while hot
Whatever you do you must check it when the oil has settled, if you have just run the car oil will be still around the engine
Make sure the car is level Mike
Post #381065 Sat Apr 20 2013 10:37pm
