| RRSPORT.CO.UK | ||
|  | Home > General > clear smoke coming from right front wheel? oil? |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Is it leaking anything? Have seen the injector leak off pipes fall out, and the diesel hits the hot exhaust underneath, causing smoke... | ||
|  Sat Apr 20 2013 2:53pm |
| ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241    | From the wheel it's very hard to see it.. Is it normal that if the car running and you pull the dipstick out for there to be smoke coming from there ? Should the oil be that hot? | ||
|  Sat Apr 20 2013 3:31pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | It can be normal, but it can be an indicator of a head gasket/piston failure, but to be honest it's difficult to tell from what you describe.
|  Sat Apr 20 2013 5:29pm |
| ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241    | Just checked the oil level and its just above the min amount.. could that be the reason? the dipstick was strange as one side says its above min but the side with the dots show it just above min...
|  Sat Apr 20 2013 7:35pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | When did you last fill it. Fill it up and make sure it's not using oil
|  Sat Apr 20 2013 7:40pm |
 Thanks. Yes coolant is fine... oil looked fine.. I didnt add oil to it as land rover serviced it 10k miles ago...i assumed the dash would tell you when to add? Whats the best way to get a true reading? I dont want to over add oil... | ||
|  Sat Apr 20 2013 7:45pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | If you have a dip stick then that's what you go off.
|  Sat Apr 20 2013 7:48pm |
 Do I check when engine cold or warm (after a run)... I checked now when cold as thats what i've always done.. | ||
|  Sat Apr 20 2013 7:50pm |
| SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324      | Engine should be warm when checking oil level. 10,000 miles without checking  | ||
|  Sat Apr 20 2013 8:13pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | Check your oil when cold
|  Sat Apr 20 2013 9:37pm |
| Posting Rules
 Monthly at least.
 Monthly at least.
