Home > Technical > Radio Low Power Mode
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
lo all,
I have a very intermittent problem which happens very occasionally.
Sometimes when driving and I have the volume on the radio over 20, it will come up and say Low Power Mode and then you cannot turn it up past 20 on the volume again until you turn the engine off and back on again.
Like I say this happens very occasionally and not on every journey.
I had a new battery fitted a couple of months ago. I get the feeling something is draining the battery power.
Any ideas?
James
Post #379898 Mon Apr 08 2013 9:12pm
Get you alternator checked out would be my first option.
Post #379910 Tue Apr 09 2013 6:42am
Bradders
As Ady says classic early symptom of an alternator on its way out. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #379919 Tue Apr 09 2013 7:53am
garrycol
Australia
Why doesn't the alternator light come on then??
I have read plenty of reports of alternator failure and there is not fault indication. In the good old days if you had an alternator failure the light would come on.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #379945 Tue Apr 09 2013 11:41am
chapman_i.t
Exactly,
I have no lights on the dash and as mentioned this happens very occasionally.
Is there anyway I can test the alternator voltage myself to test whether it is that what is causing the problem.
James
Post #379965 Tue Apr 09 2013 2:44pm
Any local garage will test it for you for free. Thumbs Up
Post #379967 Tue Apr 09 2013 3:08pm
mse
Garry
The light didnt always come on...i suppose the conditions have to be right for the light to come on on any car, a minor fault wouldnt show up Mike
2014 Facelift Discovery
Post #379971 Tue Apr 09 2013 3:54pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
I've had a u/s alternator with no alternator light, radio low power mode on mine as well. Initially AA tested alternator and said it was ok, so I replaced the battery. A few days later same fault, replaced the alternator and no more problems. If the fault is intermittent it may not show up when tested, as was thecase with mine
Post #380102 Wed Apr 10 2013 8:33pm
