![]() | Home > Technical > Battery Drainage Unfixable at Land Rover |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4513 ![]() ![]() ![]() |
I have seen instrument packs cause battery drains. Normally cured by a software update |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Hi
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Maybe try another dealer. If it's under LR warranty it should be fixed period. FF 4.4 V8 Soooo looking forward to this bad boy
They've advised it would be my local dealer only who will be dealing with this as the vehicle has been into them many times already.
I'm not so sure they can dictate which dealer you take the RRS to. The point being your local one has failed to sort the car out so you must be entitled to take it elsewhere or hand it back after you've agreed what to do about the kit etc.
Yup, time to unleash the big guns.... ![]() ![]() ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
I agree, this dealer had had many attempts to fix the car. I have had this issue in the past with a dealer.
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
have you tried the upper tailgate switch thats what was causing mine to drain |
Unbelievable that a main dealer can't find an electrical fault and just wants to give up! Really?.
I've not tried or messed with anything in all fairness.
i wouldnt trust the dealers to know this as when i had my battery drain it took me 3 weeks of testing to find it i phoned loads of dealers and they all said they have never had a battery drain i think i was 1 of the first on this forum to have this problem and since i posted many have had this same problem for the sake of £30 i would change the switch |
Sounds like a plan but as mentioned the drain is coming from the Sat Nav/Radio it freezes and doesnt turn off which is causing the drain.
