![]() | Home > General > turbo lag |
peterbell92 Member Since: 08 Dec 2012 Location: cleveland Posts: 4 ![]() ![]() ![]() |
My RR when at a standstill at a roundabout or t junction, when i require to pull off quickly. there seems to be a what seems like 2 or 3 second before the performance kicks in, then it nearly goes on the back wheels how can get power instant. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4503 ![]() ![]() ![]() |
Sounds very symptomatic of an EGR valve, or split turbo hose. A quick diagnostic session should highlight any issues |
Thanks for that disco,
Areet simples,
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
My 2007 V6 was like that.
Peter, just move the gear selector into command shift on approach to a junction or roundabout then change gear with that for a while and the gearbox will learn your style of driving and it will adjust accordingly, but i would recommend getting in touch with pete at http://bellautoservices.co.uk/bas-remap-interface/ and getting one of these. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
It's not helped by the gearbox using 2nd gear to pull away by default. You can select 1st gear using the lever in CS mode. This helps a bit.
