Home > General > turbo lag
peterbell92
United Kingdom 2008 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
turbo lag
My RR when at a standstill at a roundabout or t junction, when i require to pull off quickly. there seems to be a what seems like 2 or 3 second before the performance kicks in, then it nearly goes on the back wheels how can get power instant.
Post #377266 Mon Mar 18 2013 2:05am
Disco_Mikey
Sounds very symptomatic of an EGR valve, or split turbo hose. A quick diagnostic session should highlight any issues Thumbs Up
Post #377274 Mon Mar 18 2013 7:24am
peterbell92
Thanks for that disco,
i have had the RR in for checks. Would it of been picked up in diagnostics checks i dont know, as soon as i get home ill book it in.
thanks again
Post #377276 Mon Mar 18 2013 8:21am
simple1
2 or 3 seconds is a bit too long. Older 2.7 had a throttle delay which caught me out more than a few times especially from stand still, it was improved vastly when car was remapped. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377277 Mon Mar 18 2013 8:29am
peterbell92
Areet simples,
I might be exagerating when i say 2 to 3 seconds but it feels like it. Its a 2008, i think it might be me expecting to much from the RR. But i will definately take it to my local RR specialist and see what they say.
Again
Post #377278 Mon Mar 18 2013 8:47am
mlines
My 2007 V6 was like that.
Coming up to a roundabout or junction it seemed to decide it was going to stop. Suddenly you see a gap in the traffic and demand some power and there was a heartstopping moment whilst the engine and transmission got their act together.
I am afraid I just got to live with it although I understand re-maps can improve it, but once the turbo is winding down it takes a second or two to wind up again. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #377280 Mon Mar 18 2013 8:55am
Peter, just move the gear selector into command shift on approach to a junction or roundabout then change gear with that for a while and the gearbox will learn your style of driving and it will adjust accordingly, but i would recommend getting in touch with pete at http://bellautoservices.co.uk/bas-remap-interface/ and getting one of these. Thumbs Up
Post #377283 Mon Mar 18 2013 9:02am
It's not helped by the gearbox using 2nd gear to pull away by default. You can select 1st gear using the lever in CS mode. This helps a bit.
[I see Ady has made the same suggestion at the same time!] 2012 SDV6 - it's missing a couple of cylinders
Post #377284 Mon Mar 18 2013 9:02am
