Home > Technical > Jack/wheel brace area dimensions
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Anyone have the actual dimensions of the area where the jack/wheel brace/tow bar etc is stored? My car has black foam moulding in this area. i want to fit dual battery into this area. Along with a Traxide dual battery controller. Need something to help the situation along wrt to battery issues. I want to fit a pair of Odyssey 925M into this space. SWMBO owns this car I get to drive occasionally Smile
Post #376116 Sat Mar 09 2013 12:12pm
You do know that there is a spare battery location in the engine bay don't you? On the opposite side to the main battery.
Have you tried measuring the toolkit area in your own RRS? Or is it the depth you don't know? 2012 SDV6 - it's missing a couple of cylinders
Post #376153 Sun Mar 10 2013 12:25am
Meccles
Yes I know about the area in front of main battery, in my car I have a 6 ton bottle jack strapped there as the OEM jack is rubbish. I don't have access to my car at moment I know the actual width/length is fine, it was depth I was mainly interested in. From memory I think it is about 135mm the actual depth varies a bit as it is not flat. Was trying to organize the bits so that it could all be done when I returned home Very Happy Thanks. SWMBO owns this car I get to drive occasionally Smile
Post #376154 Sun Mar 10 2013 2:48am
mse
i thought the spare battery location was on the opposite side to the original battery, not in front of it (where the engine pre-heater lives) Mike
2014 Facelift Discovery
Post #376227 Sun Mar 10 2013 6:34pm
It is. 2012 SDV6 - it's missing a couple of cylinders
Post #376235 Sun Mar 10 2013 7:12pm
Meccles
Ok. I will have to re check when home next I can't recall there being a vacant space there on my car. It was all pretty congested there (from memory).
Traxide vendor thought that putting battery in the load space area was a good idea, low, over axle, and out of heat etc. But thanks guys will check again re the area right front of car. SWMBO owns this car I get to drive occasionally Smile
Post #376277 Mon Mar 11 2013 7:12am
mse
remove the plastic cover mayber Thumbs Up Mike
Post #376374 Mon Mar 11 2013 5:33pm
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
Rolling with laughter Rolling with laughter
Barryp 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #376387 Mon Mar 11 2013 7:49pm
Meccles
Laughing Yeah funny however I have looked under the plastic cover and inside was ABS module. All brake bits. No way a battery can fit in there. SWMBO owns this car I get to drive occasionally Smile
Post #376448 Tue Mar 12 2013 9:33am
http://www.traxide.com.au/D3_4_Index/D3_KitA.html
Depends on the kit you fit I guess...you can see the ABS module in the image on that page. 2012 SDV6 - it's missing a couple of cylinders
Post #376471 Tue Mar 12 2013 11:48am
Meccles
Thanks will have to re check the dimensions. It sure looked tight when I took the cover off...from memory...what is left of it.... Laughing Maybe need to go kill some more brain cells tonight to see if I can recall more clearly Very Happy However, when home will take it all off and re check. Maybe it is different after LRA have kindly replaced master cylinder, booster and ABS module bless em! SWMBO owns this car I get to drive occasionally Smile
Post #376479 Tue Mar 12 2013 12:27pm
Just popped out to the vehicle and a quick measure suggests approx. 250mm x 175mm x 200mm high. Which is just enough room for an Optima YellowTop 4.2S which I think is what is shown on the traxide page Thumbs Up
There are also a number of threaded holes ready to accept the battery hold down strap - a suitable LR part is available I believe.
I'm thinking of fitting an auxillary battery if we ever get around to taking the horse trailer out and about a bit more regularly - just to help with running the trailer internal lights etc. whilst still being able to start the engine at the end of the day! 2012 SDV6 - it's missing a couple of cylinders
Post #376493 Tue Mar 12 2013 1:50pm
Meccles
Just speaking to TIm at Traxide the battery strap comes with the kit. The only thing that is needed is the battery.
I will be ordering one today the thought of having additional battery reserve in the car will be a good thing. SWMBO owns this car I get to drive occasionally Smile
Post #376561 Wed Mar 13 2013 3:39am
Meccles
Well guess what. It is me who can laugh (or cry) because in my TDV8 where the second battery theoretically would fit is a computer and wiring loom. The area is completely full of ABS module, wiring loom, and module. Not sure what type of module it is but is about 100mm square 50mm deep. Will have to contact Traxide and do a swap for the kit they supplied it will not work as planned. Back to putting batteries in the cargo area..... SWMBO owns this car I get to drive occasionally Smile
Post #379783 Sun Apr 07 2013 8:14am
