![]() | Home > Technical > Jack/wheel brace area dimensions |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9157
You do know that there is a spare battery location in the engine bay don't you? On the opposite side to the main battery.
| Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 154
Yes I know about the area in front of main battery, in my car I have a 6 ton bottle jack strapped there as the OEM jack is rubbish. I don't have access to my car at moment I know the actual width/length is fine, it was depth I was mainly interested in. From memory I think it is about 135mm the actual depth varies a bit as it is not flat. Was trying to organize the bits so that it could all be done when I returned home |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
i thought the spare battery location was on the opposite side to the original battery, not in front of it (where the engine pre-heater lives) Mike
It is. 2012 SDV6 - it's missing a couple of cylinders
Ok. I will have to re check when home next I can't recall there being a vacant space there on my car. It was all pretty congested there (from memory).
remove the plastic cover mayber |
| Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261
http://www.traxide.com.au/D3_4_Index/D3_KitA.html
Thanks will have to re check the dimensions. It sure looked tight when I took the cover off...from memory...what is left of it.... |
Just popped out to the vehicle and a quick measure suggests approx. 250mm x 175mm x 200mm high. Which is just enough room for an Optima YellowTop 4.2S which I think is what is shown on the traxide page |
Just speaking to TIm at Traxide the battery strap comes with the kit. The only thing that is needed is the battery.
Well guess what. It is me who can laugh (or cry) because in my TDV8 where the second battery theoretically would fit is a computer and wiring loom. The area is completely full of ABS module, wiring loom, and module. Not sure what type of module it is but is about 100mm square 50mm deep. Will have to contact Traxide and do a swap for the kit they supplied it will not work as planned. Back to putting batteries in the cargo area..... SWMBO owns this car I get to drive occasionally |
| All times are GMT |
