Home > Maintenance & Modifications > Turbo replacement on tdv8
toplink
Recently replaced both turbos without removing the body.Job done in 2 days,not easy but better than taking thre body off!
Post #376078 Fri Mar 08 2013 11:21pm
Sell it. Now.
Look at simple1's thread http://www.rrsport.co.uk/forum/topic29765.html regarding the fallout from a turbo failure... 2012 SDV6 - it's missing a couple of cylinders
Post #376080 Fri Mar 08 2013 11:34pm
Disco_Mikey
Re: Turbo replacement on tdv8
Not really. Body can be off in 2 hours... Also gives you the chance to replace the front and front-rear brake pipes at the same time. And if it does need any rear suspension bushes, it gives great access to replace them without stuggling with tight access or seized bolts Whistle
Post #376099 Sat Mar 09 2013 9:09am
Markos
Slovenia 2008 Range Rover Sport TDV8 HSE Java Black
Mikey really only 2h Shocked is it the same for Sport? At my local LR dealer they told me that they need approx.15h( body off and on again) 2008 RRS TDV8 HSE, Java black, Alpaca,.....
Post #376126 Sat Mar 09 2013 3:46pm
Disco_Mikey
Body off in 2, providing there are no seized bolts to deal with. Each turbo is a couple of hours (ish), and allow 4 hours to refit body, bleed brakes, double check the work done and a road test Thumbs Up
Post #376133 Sat Mar 09 2013 4:49pm
RRGirl
South Africa
hi Toplink, can you advise if the turbo can be replaced without body off, please provide guide or pics
Post #520030 Mon Mar 06 2017 9:36am
Hi RRgirl, as Mike said, it's better to do it body off and it will allow access to check a whole bunch of other things. Thumbs Up --
Post #520036 Mon Mar 06 2017 10:42am
RRGirl
South Africa
Hi Naks, thanks but dont have the lifting equipment and ramp hence I am trying another way to access the turbos, any guidance and pics to assist
Post #520037 Mon Mar 06 2017 10:51am
