![]() | Home > General > Car nearly died!!! :-( help please |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
I'd get the alternator checked as it sounds like you have some pretty wild voltage fluctuations that the electronics are unable to smooth. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
I would start at the battery but as already said, get charging rate checked too. These are funny animals and need stable 14v to keep systems working properly. Over or under charging shuts things down as the voltage regulation is done by the ECU. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96
Alternator - same symptoms happened on my TDV8 last month. Rovertune did a great job replacing it at short notice. |
Battery, alternator, bad earth connection. |
| Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259
I Had the same 4 weeks ago....I fitted a new battery and hey presto I was up and running to my trusty LR Specialist garage..BUT on arrival there was a horrendous smell and when we lifted the bonnet the alternator was smoking like hell.
| 1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530
My alternator did exactly the same thing, started burning I quickly disconnected the battery and had it taken to our indie for a new one. Luckily the battery was fine, I would get the output checked asap. |
| Sirwacko Member Since: 22 Mar 2012 Location: Near Blackpool Posts: 74
New battery fitted... Drove car for about 30mins then it all happened again. Car booked in and battery on charge... Hope it will get me the 20miles to the garage!! RRS Dynamic |
alternator then |
| mjbrr Member Since: 31 May 2012 Location: Durham Posts: 81
My battery has just died too !!!
Hmmm. How long was the car at the garage? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mine didnt get 5 miles with a new battery....so make sure you have a plan B in place |
| All times are GMT |
