Home > General > Car nearly died!!! :-( help please
Sirwacko
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
I was driving home after work. Started my car and started driving, then the suspension fault light came on. Then about 2 mins later the sat mac screen went black. Then when indicating it wasn't the usual 'tick tock' it kept speeding up and slowing down. Then I got a warning message about the tailgate open. Then it said transmission failure.... Then everything went off except the engine lost all power steering and managed to limp it home. Much to the displeasure of my gf sat next to me....
Am I right in thinking this could be a battery fault a it is over 5 years old.
I've ordered the battery to fit it tomorrow.
Please if anyone has any info please share! RRS Dynamic
Post #375634 Mon Mar 04 2013 10:12pm
drdelrrs
I'd get the alternator checked as it sounds like you have some pretty wild voltage fluctuations that the electronics are unable to smooth.
Post #375644 Mon Mar 04 2013 10:24pm
simple1
I would start at the battery but as already said, get charging rate checked too. These are funny animals and need stable 14v to keep systems working properly. Over or under charging shuts things down as the voltage regulation is done by the ECU. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #375650 Mon Mar 04 2013 10:44pm
TheDB
Alternator - same symptoms happened on my TDV8 last month. Rovertune did a great job replacing it at short notice.
Post #375671 Tue Mar 05 2013 12:03am
Bodsy
Site Sponsor
Battery, alternator, bad earth connection. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #375672 Tue Mar 05 2013 12:10am
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
I Had the same 4 weeks ago....I fitted a new battery and hey presto I was up and running to my trusty LR Specialist garage..BUT on arrival there was a horrendous smell and when we lifted the bonnet the alternator was smoking like hell.
We had to disconnect the battery before it went up in smoke so dont go driving off with a new battery straight away just incase thats not the issue.
Post #375680 Tue Mar 05 2013 1:18am
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
My alternator did exactly the same thing, started burning I quickly disconnected the battery and had it taken to our indie for a new one. Luckily the battery was fine, I would get the output checked asap. Thumbs Up
Post #375704 Tue Mar 05 2013 10:46am
Sirwacko
New battery fitted... Drove car for about 30mins then it all happened again. Car booked in and battery on charge... Hope it will get me the 20miles to the garage!! RRS Dynamic
Post #375809 Wed Mar 06 2013 2:40pm
Bodsy
Site Sponsor
alternator then Thumbs Up Bodsys Brake Bible
See it HERE
Post #375821 Wed Mar 06 2013 3:50pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
My battery has just died too !!!
The day after getting it back atfer the dynamic suspension fault fix !!!
I foolishly thought it would be covered under my extended warranty..... Censored
£283 fitted with a drain test completed !!!! Censored 2009 3.6 TDV8 HSE Santorini Black
Post #375840 Wed Mar 06 2013 6:19pm
simple1
Hmmm. How long was the car at the garage? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #375842 Wed Mar 06 2013 6:43pm
Kimmea
Mine didnt get 5 miles with a new battery....so make sure you have a plan B in place
Post #375844 Wed Mar 06 2013 7:21pm
