![]() | Home > General > Towing Electrics |
| Morpheus-RRS Member Since: 29 Oct 2012 Location: Lanarkshire Posts: 83
Hi Rob and welcome to the forum, for sure the tow bar will fit but not sure of the electrics. i'm sure someone will be along soon with some help. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Same loom and layout so theory says it should be doable. If it were me I would have the swan neck and get yourself new electrics. The sockets might be protected but usually go green with time so opertunity to get some new shiney bits. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| 1014rk Member Since: 04 Nov 2012 Location: Aberdeenshire Posts: 46
| flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Very easy DIY job the only awkward bit is getting the loom around the chassis..
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
Hi Rob and welcome to the forum.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
You have to change the electrics anyway...they changed almost every year since mid 10.
| RobertNaylor Member Since: 25 Feb 2013 Location: Liverpool Posts: 12
Hi Guys, thanks for all the info. Seems a simple job except for the removal of the bumber, and advice on this would be welcome, are there any photos or diagrams to explain how to do this, Cheers Rob |
You need to fully remove the bumper to fit the electrics.
Thanks for all the help, decided to have a go. Contacted a seller on Ebay who turned out to be Beadles of Sidcup and the guy there advised the following-
My 2011 worked without activation - i activated my 13 before i fitted it Mike
MSE, How did you activate it? Or did you have to get dealer or specialist to do it? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black
Have fitted eBay system to disco 4. Only thing that didn't work properly was parking sensors. On my car they switch off when trailer is plugged in. 2x TDV6. SE and HSE. Both returned to sender with issues👀
neither...I have access to the kit
You wont have tow stability assist either...but the lights will still work Mike 2014 Facelift Discovery |
