![]() | Home > General > Ride Height |
| PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796
The IID should have stored the original settings on the first pairing with your RRS. This then enables you to restore factory settings when needed - is this not the case ? |
| scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586
Already covered here:-
| KR1005 Member Since: 03 May 2010 Location: Hong Kong Posts: 61
Thanks but that's not the case because my ride height was already out of sync, not the factory setting when I used the IIDTool. |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
You need someone to measure the distance from arch to the alloy rim (what size alloy have you got?) so you can replicate it. |
I have 22in rims
thanks a lot that's helpful |
